Juddering
Old Feb 5, 2022 | 01:47 PM
Compa's Avatar
Default Juddering
I have a Outlander GX3 2.2 DI-D 2016
Once I'm on the motorway I always use cruise control and set it to around 75mph. After a few seconds or when I go SLIGHTLY uphill where the car has to work a tiny bit harder the vehicle start to judder softly then roughly.
soon as I disengaged the CC the car is fine!
I'm booked in this week for a diesel carbon clean this week as I'm trying to work through possibilities. Anyone know any info on this would be muchly appreciated. Cheers
Old Feb 7, 2022 | 12:30 PM
daem0n's Avatar
Can you confirm that vehicle does not switch to lower gear when driving slight uphill?
Have you tried to drive on the same road with the same speed (keeping it constant) but with CC turned off? I assume you have A/T.
Old Feb 7, 2022 | 12:58 PM
Compa's Avatar
It is manual, 75mph!! Even does it on the flat. When CC is off its fine. And no, its 6 speed manual. 2.2 DI-D 2016 GX3
Old Mar 17, 2023 | 12:23 PM
Lou895x's Avatar
Default Juddering
Hi any updates mines a 2014 2.2 diesel gx4 auto outlander adsacly the same thing has happened in curse and bang started juddering no codes on dash nothing macanics are at a standstill have no idea keep relacing parts, has had new dpf, new trottle body, maff sensor and still happening every so often. HELP PLEASE!
Was told it might be the injectors also fuel line?
Thanks
Louise
Old Mar 18, 2023 | 03:48 AM
daem0n's Avatar
I would advise to visit the Mitsu authorized workshop and update software/firmware for ECU, gearbox, 4WD control unit etc modules. It is clearly a SW bug, perhaps, an A/T does not switch to lower gear in time or at higher load when CC is activated.
Old Mar 18, 2023 | 12:25 PM
Lou895x's Avatar
Thanks so much going to mitsubishi dealer on monday and will tell them what you've told me and hopefully its an easy cheap fix thanks for helping much appreciate was giving up hope on the outlander as trying to diagnos the problem is a nightmare with no warning light and contantly replacing things i think it might be.
Thanks again!
Chrisyd89
Mar 28, 2019 04:06 AM
watts_451@hotmail.com
Feb 7, 2019 03:13 PM
Gumby789
Apr 30, 2016 06:20 PM
titus1991
Jan 24, 2015 12:13 PM
