LED Floor illumination Outlander Sport?
Old 07-21-2011, 09:50 PM
Jmant83's Avatar
Default LED Floor illumination Outlander Sport?
Has anyone figured out how to install the floor illumination kit? Is there a terminal specifically for this? If so I would like to tap into it for my own set of LED strips. Anyone have experience with this or installed LED strips in the Outlander Sport?
Old 07-26-2011, 04:36 PM
atx25rs's Avatar
i have been looking into doing this, but havent gotten around to it. have you checked the service manual?
Old 07-28-2011, 04:53 PM
xOutlanderFiendx's Avatar
anyone install floor lights period?
Old 07-29-2011, 01:37 PM
Jmant83's Avatar
I poured over the service manual and I do not see any mention of how the floor illumination kit is installed. In the end I decided to install my own LED strips using an Add-a-Circuit to get +12v to them and grounding them at the dome light switch wire. I was going to add a relay for a manual switch but decided it was too much of a hassle. A little later on I can provide a more detailed tutorial, but that will probably wait till i get my side emitting DRLs installed.
Old 07-29-2011, 02:17 PM
I look FORWARD to seeing this tutorial !!!!
I would try it myself but the tutorial will help a lott !
Old 08-01-2011, 01:19 PM
Jmant83's Avatar
Required Materials and tools
Quick Splice for Ground wire:
Quick Splice Connector with Male Disconnector (3-Pack) - RadioShack.com
Add a Circuit for constant +12v with 5 amp fuse:
Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
Wire:
20 gauge speaker wire is sufficient
1/4 inch heat shrink:
Dorman/Conduct-Tite 1/4 in. x 8 ft. black heat shrink tubing (85265) | Heat Shrinking Tube | AutoZone.com
Connectors:
1/4 inch male/female crimp quick disconnects.
1 Hair dryer
1 Metal Clothes hanger
Wire stripper
Needle nose plyers
Optional components if you want a manual switch as well
Optional Relay and harness:
5 Pin 40 Amp Relay
5 Pin Relay Harness
Optional Switch:
SPST 16A 125V Illuminated Round Rocker Switch with Red LED - RadioShack.com
Old 08-01-2011, 01:21 PM
Jmant83's Avatar
LEDs Used:
4 x V-LEDS 6K White Strip Light 12 LED 12 inch
I will add the tutorial after work today.
Old 08-01-2011, 03:50 PM
Originally Posted by jmant83
leds used:
4 x v-leds 6k white strip light 12 led 12 inch
i will add the tutorial after work today.
excellent!!!
:d
Old 08-01-2011, 03:52 PM
you also mentioned side emitting DRLs, can you elaborate on what exactly your going to do with ur DRLs?
Old 08-02-2011, 11:32 AM
Jmant83's Avatar
They will go on the top side of the headlights to act as day time running lights. I think a few others on this forum have done this as well, I will post a tutorial on that in another thread when it is completed. Just waiting on V-LED to release those.... the sales person says they should be coming out very soon.
I finished the install of the floor board lighting yesterday. I will take pictures and a video of them in action to go along with the write up.
Quick Reply: LED Floor illumination Outlander Sport?
