Lights flicker and knocking sounds with heater on.
I didn't notice it before, but I did now... Basically, the lights would dim when AC or automatic climate is on. Also, when automatic climate is on (no A/C) I hear some knocking sounds every 20 seconds or so. It's especially noticeable when idling. Anyone?
RE: Lights flicker and knocking sounds with heater on.
Most cars do this, the extra load imposed on the alternator/ generator by the air con/climate control is the cause of your lights dimming, if you increase the engine revs slightly the lights should get brighter. The clicking noise will be coming from the compressor from the air con/ climate controlsystem. This is normal and should be nothing to worry about.
Ron
Ron
Thanks Ron! I am a little disappointed because our other car (08 Sentra) doesn't have this issue. At least I cannot hear the "knocking" sound while idling at the light. Although, I think it's a different subject though with Outlander interior noise isolation in comparison to Sentra...
MrGalantGuy
11-18-2014 12:53 PM
tyson724
11-14-2008 06:00 PM
p4c0
02-22-2007 06:36 PM
