Mitsubishi RVR ( Outlander Sport ) 2017 Head Unit Replacement
Old Jan 28, 2019 | 08:40 PM
Lasvad's Avatar
Default Mitsubishi RVR ( Outlander Sport ) 2017 Head Unit Replacement
Hey everyone,
I've recently been trying to install a Sony XAV-AX100 for Car Play. I purchased the adapter to convert the existing adapter to the new HU and that is working fine. What I'm currently struggling with is trying to hookup the reverse camera. The Sony XAV-AX100 takes a RCA cable while the old HU had an 8 pin connector. I looked online for any documentation for the 5MU6R69-T existing HU but can only find docs for an older version 5MU4R69-T (I'm assuming based on the 4 instead of a 6 on mine, https://elektrotanya.com/mitsubishi_.../download.html). The older model has the same 8 pin connectors, but only uses 6 while mine uses 8. I've tried to use the old guide to find the which wires are for powering the camera and which is for the video source. Unfortunately I believe I was incorrect because when I used a voltmeter on the wire I thought I had to supply power, it already had 14 volts...
Has anyone replaced a 5MU6R69-T HU? Does anyone know where I could find a manual for mine? How can I determine which cable is for the video source and which is for the power the camera? I assumed using a voltmeter would help, just not sure what to check for.
Any help would be much appreciated.
Cheers
Old Jan 28, 2019 | 08:47 PM
Lasvad's Avatar
Some images of my old unit.
ProfessorFalken
Nov 13, 2023 10:04 PM
dlin04
Nov 8, 2020 01:45 PM
btufail
Aug 18, 2017 05:56 AM
btufail
May 10, 2017 10:37 AM
joshdolphins1
Jun 9, 2011 11:13 PM
