MMCS HDD Structure
Old May 9, 2015 | 08:16 AM
  #21
polik71's Avatar
Originally Posted by bobmoss
I've just swapped my drive for a 64Gb SSD drive and can confirm it is working OK.
I got the drive from Amazon here in the UK (it was £40.00) and it is a:
Zheino CHN-25PATA01M-064 - 2.5 Inch Pata 44pins Ide Solid State Drive 64gb for IBM Laptop
The MMCS now boots up much quicker and the navigation screens are much faster (zooming in and out, selecting streets etc.).
Hope this helps someone.
Good to know this! I was also hoping in some kind of list here of working HDD / SSD make/model. That would be great as an upgrade.
BTW , someone that knows if a new EU map version is available "somewhere"?
Old May 9, 2015 | 11:42 AM
  #22
Vadimus's Avatar
It is for sure.
Old May 9, 2015 | 12:43 PM
  #23
draytek's Avatar
Default eu250
(Link by PM only) I am looking for a citroen aircross nr262em c-02 cloned hdd image. Thx
Old May 9, 2015 | 04:19 PM
  #24
astina's Avatar
Originally Posted by draytek
I'll send you the link for the new european maps 2014-A
If it's possible I will be very glad to have the link too
Old May 10, 2015 | 11:35 AM
  #25
ragga's Avatar
hi draytek can you send a pm for that upgrade for the maps .
cheers bud
Old May 11, 2015 | 02:19 PM
  #26
polik71's Avatar
Thanks draytek. My collegue will let me know about his Citroen model navi system...
One thing to add to the CD updates (if is not written here somewhere) is that you need to burn them in ISO mode , not the UDF filesystem. I had the navi not recognize the last format.
M.
Old May 12, 2015 | 04:41 PM
  #27
polik71's Avatar
Hi draytek ,
I can confirm that the nav system in my collegue's Citroen C5 is NOT our MMCS :-/
Sorry for that.
BTW I have the EU map update file and a "suspicious" Hands-free-v1800-update file : anyone can update me (again??? ) on how to load them?
Thanks in advance!
M.
Old May 14, 2015 | 05:15 AM
  #28
bobmoss's Avatar
The Amazon link is: www.amazon.co.uk/Zheino-44pins-Solid-State-Laptop/dp/B00QQ7TKS4
A quick update on this - unfortunately it doesn't work after a cold boot, I get the "Please insert a program disk" message.
Sorry if I got anyone's hopes up!
Old May 14, 2015 | 10:46 AM
  #29
ragga's Avatar
WORKING
much faster on all functions
Model: CHN-25PATA01M-064
General Form factor 2.5 Interface PATA Performance Capacity 64GB Sustained Read 112MB/S Sustained Write 60MB/S Random IOPS
4KB Random Read IOPS
4KB Random Write IOPS
Average Access time 0.2ms Storage Media NAND Flash MLC- NAND Flash Power Consumption input Voltage 5V+/_5% Idle 0.5W Active 2.0W Reliability& Endurance Write endurance 80years@10GBytes write and erase per day at 32GB Read endurance unlimited Wear-Leveling Algorithm Dynamic and static wear-leveling Data Retention 10years at 25ºC MTBF 1,000,000hours ECC Supports BCH ECC 8bits or 15bits in 512 bytes Bad Block Management Auto Bad Block Management in system Environment Operating Temperature 0~70ºC Non-operating Temperature -40~85ºC Shock 2,000G(@0.3ms half sine wave) Vibration 20G(40-2000HZ) Ambient Humidity 5-95% Warranty 3years
Old May 15, 2015 | 07:30 AM
  #30
ragga's Avatar
done cold boot from install hdd and tryed by unpluging cables on the back both booted fine for me
