MMCS HDD Structure
Old May 15, 2015 | 09:06 AM
  #31
Vadimus's Avatar
Originally Posted by ragga
done cold boot from install hdd and tryed by unpluging cables on the back both booted fine for me
Did it go through "Program update" sage upon cold boot?
Old May 16, 2015 | 06:32 PM
  #32
ragga's Avatar
can't remember what came up on the screen somthing about hdd and then started loading and then mitsubishi logo.
if that helps
Old May 18, 2015 | 03:56 PM
  #33
bobmoss's Avatar
Interesting - still can't get it to cold boot here.
What did you use to copy the data onto the SSD drive?
Old May 31, 2015 | 03:22 AM
  #34
ragga's Avatar
how i done it, first thing copied all data from each partition by copy and paste.
then used macrium reflect pro to to copy main partition the first 3, had an error at 75% but had created the partition's, so then copied the data over by copy and paste , then created the last 3 partitions with the last one for music being bigger that original.
because the macrium reflect had created the partitions ,it had copied the hidden boot up info ,plus must set in windows in folder and files that all files can be seen no hidden, for when you copy and paste.
hope this helps
up date
the prg that i used for the partitions was
EaseUS Partition Master Professional 10.5
brian360
Aug 3, 2023 01:23 PM
bertsch
Feb 28, 2016 08:40 AM
baat2
Mar 2, 2012 07:28 AM
hogar
Jul 31, 2011 06:39 PM
Malmskov
Feb 12, 2008 09:53 AM
