MMCS - help needed
Hi Everyone,
I recently bought a used C-Crosser MMCS unit which I have installed in my 2008 Outlander. It all works, but I have a couple of issues. Hopefully some of the knowledgeable people on this forum can help me.
1 - Can I apply a dvd-in-motion patch on this C-Crosser unit? and how do I access the secret menu to confirm the version number? I tried holding the SET+NAVI buttons, but this does not appear to work. Is there another method?
2 - Is it possible to change the start-up screen picture from Citreon to Mitsubishi?
3 - The small joystick seems to be faulty – it only scrolls up and does not click enter – does anyone you know if this is a common fault and is it possible to repair / replace this?
Hopefully you Guys can help answer my questions.
Many Thanks
SSD
Many Thanks
SSD
Hi - can anyone help with my questions?
I've tried to access the service menu using the NAVI+SET buttons, but this does not seem to work on my C-Crosser unit. Does anyone know if the C-Crosser version has a different method of accessing this menu?
I've also tried to unlock the HDD using the key's provided on this forum, unfortunately they don't worth either.
The model number on the back of my unit is:
NR-261EM-07CTR0
C-01
Any clues or help would be most welcome.
Thanks.
NR-261EM-07CTR0
C-01
Thanks.
Hi Everyone,
Many Thanks
SSD
Many Thanks
SSD
2. Yes
3. Mechanical issue - it is reparable/replaceable.
