MMCS Lost Music Server
Old Oct 19, 2008 | 07:18 PM
OzarkXLS's Avatar
Default MMCS Lost Music Server
Greetings,
I have the US version of the MMCS with all the forum upgrades. The newest gracenote and the DVD unlock. All work well. Today I decided to remove music that was automatically added to the Music Server provided by my kids. So I followed steps 1-3 on page 7-8 of the MMCS book for 2007 units. Step three gives you the choice of "delete all" which I figured was easiest as I have the original CD's of the music I want on the server. The unit deleted then reset from start, the music server is now dark, the "Original" folder and the "My Best" folder are gone. There are now no folders in the Music Server. With the dark screen I cannot use the ^ key nor any other functions in the server, all I get is beeps. Anyone got ideas? Did I erase the whole server program? Someone got a fix?
Old Oct 19, 2008 | 07:20 PM
brian360's Avatar
Default RE: MMCS Lost Music Server
Is it possible that is just how the music server behaves when there is no ripped music to play? Try ripping a CD and see if it starts to work.
Old Oct 19, 2008 | 09:00 PM
OzarkXLS's Avatar
More,
I burned a CD of 38 MP3's and played it, in the past the music server picked right up on the CD and added it to the playlist. I played the CD while taking a 45 minute drive, no luck. I can take a store bought CD and give that a try. The book said someplace that the "original" and "my best" folders could not be deleted. The book is wrong. I was wondering if one of the upgrades I happily installed left a door open and I found it.
Off to play a factory CD.
Old Oct 19, 2008 | 09:12 PM
brian360's Avatar
Right, you have to use a factory CD. The Music Server does not rip MP3 cds. I think the "original" and "my best" folders are gone because you deleted all your other music, so of course original and my best have nothing to show. They will probably reappear once you rip an original music cd.
Old Oct 19, 2008 | 09:42 PM
OzarkXLS's Avatar
Interesting. I took a Santana CD and played it, the Gracenote picked it up and voila, both folders came back and recorded the CD with title. Now the interesting part, all the MP3's I burned play fine on the CD but the server doesn't record. Is this because I used untitled (volume label) during the burn process? Could it be because I use a third party internet site to download music? All the Artist names and song titles are listed.
Thanks for the reply Brian, it helped.
Old Oct 20, 2008 | 11:20 AM
brian360's Avatar
As I said earlier, the music server will not record mp3 cds, only normal audio cds (the kind where you're limited to 80 minutes). Reburn your CD as a normal audio CD and the music server will record it. If you want track names, make sure you burn your normal audio CD with "CD-TEXT" (most software should do this for you).
Old Oct 20, 2008 | 03:06 PM
tdford's Avatar
Yes you deleted all the saved music that was stored under the Music Server. Since there is nothing in there now, the button is "greyed" out. And as you described yes, once you rip more music into the Server the button then becomes available.
And yes, it will not rip mp3's...
Sophie Hemmington
Feb 23, 2014 02:37 PM
red123
Mar 4, 2011 05:28 AM
kma_johan
May 30, 2009 08:58 AM
Krokusmtl
Oct 23, 2007 05:17 PM
ash
Sep 2, 2007 05:32 AM
