MMCS Sirius radio update killed radio-2007 Outlander XLS
Old 11-12-2008 | 02:30 PM
rosetex's Avatar
Default MMCS Sirius radio update killed radio-2007 Outlander XLS
This morning SIrius radio updated a "channel" lineup. After the update...I was able to receive the channels. Turned the car OFF. Started the car again and the Sirus radio displayed " Antenna Error" .No channels showed and all other fields greyed out. Contacted Sirius support and call taker said was the 2nd call on this subject.
I took into the dealer. He tried unplugging the Module and still has problem. Awaiting answer from Mit tech support to dealer.
Old 11-12-2008 | 02:32 PM
brian360's Avatar
Default RE: MMCS Sirius radio update killed radio-2007 Outlander XLS
Strange. My car handled the update without any problems. Did you try disconnecting the battery cable for a few minutes to force the Sirius module to reset?
Old 11-12-2008 | 02:36 PM
rosetex's Avatar
Not yet...Will try this evening...Thanks
Old 11-12-2008 | 02:44 PM
jsrd's Avatar
Another option is pull out the #7 fuse from interior fuse box and reinsert a few minutes later. . .
Old 11-12-2008 | 03:16 PM
rosetex's Avatar
Thanks for the response...I couldn't locate the fuse box Inside...Found the one in the engine compartment.
I pulled the #30 IOD ...waited 1 minute.
Problem resolved.
Thanks again for both posts..sent me in right direction.
Old 11-12-2008 | 03:25 PM
rosetex's Avatar
Next time...I'll try to give more info...Newbie Problem.
2007 Outlander XLS, MMCS,HID,650 watt sound system, sunroof,18in wheels,all Leather interior
Old 11-12-2008 | 03:45 PM
jsrd's Avatar
Excellents news, rosetex. Here a pic with Fuse # 7, for reference in the future. . .
Old 11-12-2008 | 05:08 PM
ruchuck's Avatar
oh man my 2007 is having the same problem. I have been depressed over it all day. I am going to give the fix a try. I realllllly hope it works
________
marijuana seeds
Old 11-12-2008 | 05:32 PM
ruchuck's Avatar
yes!!! it worked. old #7 did the trick
________
full melt bubble hash
Old 11-13-2008 | 10:53 AM
brian360's Avatar
After thinking I was in the clear, just this morning my Sirius module did the same thing ("Antenna Error"). Looks like a lot of people are affected by this. I will try to reset the module this evening by pulling the fuses as suggested. As a software engineer myself, these types of problems with embedded appliances that should "just work" really disappoint me... Welcome to the world of poorly tested over-the-air software updates
Quick Reply: MMCS Sirius radio update killed radio-2007 Outlander XLS
