Mp3 player wiring for Outie LS
Old Jun 5, 2009 | 05:33 AM
scotdail's Avatar
Default Mp3 player wiring for Outie LS
So, I have a 2007 LS model. It does not have any packages. There is no wiring in the console that I can see for the RCA jacks or MP3. I want to hook it up. Wondering if anyone has done this without purchasing the dealer kit? If so, info and possibly photos appreciated!
When I pull the radio, I see two bulkheads attached, and the smaller of these has a 3 wire pigtail off of it with a small connector. Wonder if this is where the harness for the Mp3 connector normally attaches?
Old Jun 14, 2009 | 08:58 PM
scotdail's Avatar
Alrighty then - anyone have a wiring diagram to the radio unit then??
Thanks,
Scot
Old Jun 15, 2009 | 12:11 AM
jsrd's Avatar
scotdail, I hope what this help you. You need to connect to C-15 (18 pin) three wires in order to qualify AUX mode in your radio and that you can connect your mp3 player, of the following way:
In the opposed end to C-15 harness, you would have RCA/jack connectors to connect your mp3 player selecting AUX MODE in your radio, for example:
Thank's to ozoono by the pics.
Old Jun 15, 2009 | 07:47 AM
scotdail's Avatar
Excellent! This is exactly what I was searching for. Thank you kindly!
Scot
Old Jun 25, 2009 | 07:00 PM
scotdail's Avatar
Hmmm... the harness looks much different in my 07 than the one pictured here. The bulkhead connectors and wire colors are different. Are these pictures from an 07-09 Outie?
Viola! It worked like a charm. I used a standard cable from a computer sound hookup. Thanks for all the help!
Old Jun 25, 2009 | 09:02 PM
jsrd's Avatar
Congratulations scotdail ! , and the pic Yes it corresponds to the Outies 07-09.
Old Jun 25, 2009 | 09:58 PM
scotdail's Avatar
Several of the wire colors in C-15 were different in my XL than those shown in the picture - just an FYI...
For anyone interested in doing this, you can get the connector pins from a scrap harness at a stereo shop. They usually have plenty around. I went to Best Buy, they were very helpful. Cut the bulkhead connector apart to remove the pins and wires. Cut off one end of a Mp3 player jumper cable, and splice the pin wires onto it. Plug it in according to the diagram above.
It was really very easy. Since I had most of the parts lying around, it was also free. If you don't have the parts, maybe $10?
Old Dec 26, 2009 | 10:06 PM
mhc1990's Avatar
Default post pictures
scotdail, can you please post some photos of your work. I have a 07 outlander with navigation and I have no idea where the C-15 connector is located. The pictures posted in the threads are not similar at all to my unit. Thanks in advance.
Old Dec 28, 2009 | 07:18 PM
jsrd's Avatar
mhc1999, look here:
https://mitsubishiforum.com/forum/sh...ighlight=c-117
https://mitsubishiforum.com/forum/sh...hlight=harness
In MMCS, C-07 replace C-19 and C-15 from CDradio, so you need find the next wires in C-07, and selec AUX MODE from MMCS to play your device:
Video IN - End 47 - Blue
Audio R IN - End 48 - Blue/Green
Shielding - End 49 - Blue/Red
Audio L IN - End 64 - Blue/White
Shielding - End 63 - Black/Pink
Good luck
Old Jan 31, 2010 | 10:15 AM
stundies's Avatar
Where do I buy one of those modules with the Stereo Jack one end and the Red/Black?white wires the other?? I have scoured eBay but can't find the right description to search for as I only come back with iPod Leads. Has anyone got a link?
Also, can I get a module that will allow me to connect a USB stick with mp3 files on that will allow me to play it through my single shot CD player (not MMCS Satellite Version)??
