Navi Unit and Bluetooth
I've read on a variety of posts about a "hidden" menu on the Navi unit that you can use to change certain default settings. I've got a Rockford head unit and the factory fitted rear system. . . .
Question 1 - is the replacement of the RF Head unit to the Navi unit a fairly painless operation?
Question 2 - my car does not have the factory, on-board Bluetooth kit. Is it available as a retro fit and, if so, is it also a fairly simple wire up?
Question 3 - According to my user manual, the car can be configured to auto-unlock the doors when placed in Park. My "dealer" says he can't do it. Is this done from within the car OR via an external interface?
Question 4 - Has anyone retro fitted the rear park-distance control?
First off, yes the Nav has a menu that allows you to change settings like: auto unlock in park, rear wiper, chirp when locked, lights flash when lock... etc
1) there is a kit that allows you to swap out the head unit and install the Nav, if you dont know much about head units and wiring, I would let the dealer do it. There are some people on here that have done it, they will be more help with install...
2) you can install the factory bluetooth as a kit: http://www.mitsuaccessories.com/Merc...ory_Code=OUT07
This will probably require taking apart the steering column... might want the dealer to handle this.
3) like I said above, with the nav there is a menu that can do all these changes. I changed the doors to unlock when put in park the 2nd day of having the Outtie. Its possible, but without the nav its a sequence (like a code) that can be done. The dealer can get the codes for this.
4) my US '07 didnt come with rear sensors, so I dont know if you can change this
ORIGINAL: WhiteAfrican
tarmacES
Sep 29, 2008 11:35 AM
Dusty Eclipse
Apr 10, 2008 10:42 AM
