Need Help !
Old Nov 10, 2008 | 01:13 PM
jzielinski's Avatar
Default Need Help !
I just got my new 2008 outlander, and I've been told that eventough I did not take the Fosgate upgrade it was still pre wired for a subwoofer... I can't find anything in the back, maybe I am miss understanding the Pre-wired part... does anyone know where to look for those wires, may offer a picture that wood be great...
Thanks
Jaro 8
Old Nov 10, 2008 | 05:09 PM
mitsupartsman.com's Avatar
Default RE: Need Help !
its connector D15
Old Nov 11, 2008 | 03:22 AM
BrodyGuy's Avatar
if its pre wired for a subwoofer does that mean its also prewired for an amplifier? i ask because i find it hard to believe that they would secretly shove an amp in the vehicle and just not tell you about it.
Old Nov 11, 2008 | 07:48 AM
jzielinski's Avatar
Thank you for the drawing, it makes sense now..
I guess I would need a harness to tap into this d15 plug... is that available OEM or must buy it from a dealer? can you also offer a part number??? (it seems you have the info) thank you!
Jaro 8?)
Old Nov 11, 2008 | 09:22 AM
ORIGINAL: BrodyGuy
if the vehicle is prewired for the sub it must be prewired for the amp. that dosen't mean it has an amp it just means the wire connector is there.
to install the subwoofer you would need to install the amp.
there is also a plug for an inverter to run a 110volt outlet. but no inverter.
Old Nov 11, 2008 | 05:16 PM
BrodyGuy's Avatar
where is the plug for the inverter?
Old Nov 11, 2008 | 06:53 PM
jsrd's Avatar
Hi BrodyGuy, look in the next link, https://mitsubishiforum.com/m_230963/tm.htm, there is the procedure to locate this connector (D-128), and this link, https://mitsubishiforum.com/m_235391/tm.htm, has circuit diagram for AC Inverter. . .
Old Nov 11, 2008 | 11:22 PM
BrodyGuy's Avatar
awesome sounds good, thanks
Old Nov 12, 2008 | 08:05 AM
chenarm's Avatar
In the other thread you had listed the parts:
- AC plug p/n mn141360 $35.00
- console box p/n 8011a410 $30.00
- inverter under the pass seat p/n 8638a001 $325.00
Does it really need to be the OEM inverter? it's fairly pricey. Does anybody have the specs on it, i.e. power output? I was thinking of getting and after market one and using the same connector, looking at the wires on the connector from the pictures I imagine it can't be a very power full one, maybe 200W max?
Old Nov 12, 2008 | 08:21 AM
BrodyGuy's Avatar
for that kind of price, you may as well just get one that you can plug and play into the existing power outlets.
