Need help/suggestion from cvt experts
Old Sep 1, 2014 | 11:18 AM
Oscar Belzares's Avatar
Default Need help/suggestion from cvt experts
Hi all
Tomorrow I want to drain and re fill my cvt gearbox oil, but I'm concerned about that some old oil will be kept inside the gearbox and will be mixed with the new one. I got an oil sample of both and they have a big difference of color, the old one is like gold/brown and the new one is clear green. The new oil is genuine from Mitsubishi the cvt f J4.
So my question for the experts is, will it be ok to make this drain and re fill and then old oil and new oil will be mixed? Could it create any problem in the near future
Old Sep 1, 2014 | 02:04 PM
Akzle's Avatar
highly unlikely to cause problems.
If you are really really concerned, drain, fill, drive, drain, fill.
Old Sep 2, 2014 | 12:05 AM
Thanks Akzle
Feel better, I will go for drain and re fill one time and monitor behavior.
Old Sep 2, 2014 | 12:12 PM
Originally Posted by Oscar Belzares
Thanks Akzle
Hi, just a quick update of my oil change, it went good, I could got 4.7 liters from it, and then I made the refill and a test drive and it felt more smooth than before.
Old Sep 2, 2014 | 12:22 PM
JRK5892's Avatar
any chance you took any pics of this process and could do a how to write up to help out the comunity on here? i have to do my trans and gear box this weekend, would be great to have that guide
Old Sep 3, 2014 | 01:33 AM
Hi JRK5892
Unfortunately I did not take pics from the process I did since I was a little bit nervous doing this in first time, but I can describe the steps I did:
1) Start the engine and leave it in idle for 10 minutes, then do a 5 minutes drive.
2) Remove the drain plug from the bottom of the gearbox case to drain the transmission fluid in a container. It will take around 20 minutes the whole draining. I got 4.7 liters from it.
3) Put the drain plug back.
4) Be aware of how much oil you took from the the gearbox so you re fill it with the same amount of new oil.
5) Add new transmission fluid (Genuine Mitsubishi CVT fluid J4) through the oil filter tube. I added exact the same amount that I extracted from it. 4.7 liters.
6) Start the engine and make a slow test driving for a couples of minutes and then do it faster and make sure everything is working as expected.
7) Stop in a safe place and measure the oil with the engine running and in Neutral position. It should be between cold and hot level.
8) Enjoy
Notes: Color or appearance of both oil:
Old: dark gold, smelling was ok like regular ATF fluid
New: Light green, smelling totally different as the old one.
I hope this helps!
Old Sep 4, 2014 | 05:42 PM
JRK5892's Avatar
Thanks!
Old Jul 28, 2015 | 11:20 AM
grumpyrom's Avatar
Does the washer for the drain plug have to be replaced with each fluid change? I'm doing mine for the first time this weekend and my local dealer doesnt have it in stock. Will it likely be ok to reuse the same washer?
Old Jul 30, 2015 | 12:59 PM
gggplaya's Avatar
How many miles are you changing it?? I imagine if you do it every 30k miles like some people, you would never have to do an actual flush. Just drain fill, 30k, drain fill, 30k drain fill etc...
Outie_NZ
Jan 25, 2025 05:55 AM
LostSoul
Sep 11, 2009 11:07 AM
blueshirt600
Apr 18, 2007 02:51 AM
MirageGTR_09
Jul 18, 2006 08:39 PM
good_land
Mar 17, 2006 12:09 AM
