new rotors
new rotors
http://www.tirerack.com/brakes/brake...ar=&perfCode=S what do you think of these, i found them searching for a cheap quality brand for rotors for the outtie and decided that i should go ahead and pick these up. i know there are better brands out there but does anyone else have any experience with these
RE: new rotors
My limited knowledge of rotors is this;
The drilled and slotted rotors are designed to help dissipate the heat generated while braking, thus increasing efficiency and decreasing the braking distance. I think it would help on repeated braking as in a track or race application. But, if you are driving like every other regular joe, you may not nitcie the difference in stopping at 155 feet instead of 160 feet while slamming on the brakes.(random numbers, not test results obviously) Most of the Outlanders were not equipped with ABS, so braking will be subjective to the driver and his/her reaction time and application. In my opinion, unless you have a lot of engine mods where you will be exercising the power gains via faster speeds more often, or you need to upsize your rotors due to 20" rims, leave the stock ones on. But. they do look pretty cool even if you don't NEED them. How much of what we do to our cars do we absolutely NEED.
RE: new rotors
i have twenties on mine so i think i would see an increase in braking performance. as it is right not, i get some brake fade and the brakes dont lock up anymore like they used to. i know that locking up is not good but the fact is that they dont do it anymore. looking around some more i found some rotors on ebay for 65 and will probably get those instead, that way if there is no performance gained then i wont be out too much money.
