New TSB for 2007 Outlander?
Old Nov 18, 2008 | 11:25 PM
cybergoogle's Avatar
Default New TSB for 2007 Outlander?
Hello ... can anyone verify the following 2 TSB[/align]TSB-07-13-010: DTC P0657 P1590 U0101 P0201-P0206 & POSSIBLE NO START [/align]
TSB 08-13-007: DTC P0300-P0306 and Rough Idle[/align][/align]
Old Nov 19, 2008 | 06:51 AM
mitsupartsman.com's Avatar
Default RE: New TSB for 2007 Outlander?
what part of them would you like verified?
Old Nov 19, 2008 | 07:42 AM
For US model [/align]
Old Nov 19, 2008 | 05:07 PM
yes they are US model tsb's one is for a ecm reprogram adjusting for poor gas quality and the other requeats replacing relays that may malfunction if condensation gets inside and freezes.
Old Nov 19, 2008 | 06:40 PM
Melvin8078's Avatar
Are these TSBs only for US models?
Old Nov 20, 2008 | 08:56 AM
here's a copy of 07-13-010 note that this repair is for certain conditions and has been updated on the newer models.
Old Nov 26, 2008 | 05:30 PM
armymen's Avatar
that appen to me last year,
I was abble to start, when i put in reverse, a Big CLUNCH, i tough my transmision brake,
then put in park, stop the car, try again, same thing Clunch.
Then stop the car, try again, the car reverse, then when i when to drive, cannot go faster than 10 km/h.
heyha.
Fix last years
Old Feb 12, 2018 | 06:03 PM
donpino's Avatar
Default Transmission still shift hard after replacing faulty relays
Here in Canada it’s bitter cold and had the problem related to the TSB−10−13−002 faulty relay freezing (accumulate humidity) for models 2007 to 2010. It results in vehicle no start or a number of other problems as relays do not sent the signals. Over the last 10 years Mitsu first replaced the 4 black relays (1 for cvt, 1 for throttle, 1 for starter, 1 for ignition) with green relays, same problem. Then replaced the green with blue relays, same problem, now replacing with other newer black (but mecano recommends light grey from Bosh). After replacing my blue relays with the Bosch relays, I read my codes and P1590 and U0101 both related to the cvt transmission. Codes are not erased yet, but I still have hard shifting in reverse. How do I get rid of this problem which should have dissapeared after replacing the relays..... Do I have to reprogram the transmission unit or is it going to get away after some relearn? I was told by a mechanic that it may take something like 50 start before the transmission adjusts. ??????
alsaaron
Feb 12, 2014 10:56 PM
ruski
Feb 17, 2011 04:01 PM
klas
May 16, 2008 06:02 PM
Winshawn
Sep 14, 2005 02:32 PM
GTAlander
Sep 1, 2005 11:28 PM
