OBDII Live Data
Old May 25, 2009 | 11:45 AM
ccernst's Avatar
Default OBDII Live Data
I have an Actron 9180 scanner that I use on my truck and the outlander. I was playing with the outlander and recorded some data off of it. What looked really odd was the number of duplicate values.
MIL STATUS($00) OFF
MIL STATUS($01) OFF
ABSLT TPS($00) 12.5
ENG SPEED($00) 644
ENG SPEED($01) 651
BARO PRS($00) 97
CALC LOAD($00) 33.7
MAF FLOW($00) 4.80
MAP($00) 36
OUT TEMP($00) 102
COOLANT($00) 183
COOLANT($01) 183
IAT($00) 102
IGN ADVANCE($0 11.0
ST FTRM1($00) -5.1
LT FTRM1($00) 3.1
ST FTRM2($00) -1.0
LT FTRM2($00) 0.0
VEH SPEED($00) 0
VEH SPEED($01) 0
ABSLT LOAD($00 25.0
FUEL SYS 1($00) CLSD
FUEL SYS 2($00) CLSD
REL TPS($00) 4.3
REL TPS($01) 0.0
THROT CMD($00) 4.3
ABS TPS B($00) 13.7
ACC POS D($00) 19.6
ACC POS D($01) 0.0
ACC POS E($00) 9.4
EGR COMMAND($0 0.0
EVAP PURGE($00 12.5
EVAP VP($00) 1.029
CMD EQ RATIO($ 0.999
O2S11($00) 0.260
ST FTRM11($00) -5.1
O2S12($00) 0.160
ST FTRM12($00) -5.1
O2S21($00) 0.080
ST FTRM21($00) -1.0
O2S22($00) 0.180
ST FTRM22($00) -1.0
CLR DIST($00) 2028
CLR DIST($01) 32869
CLR TRPS($00) 47810
CLR TRPS($01) 65464
MIL DIST($00) 0
MIL DIST($01) 0
FUEL LEVEL($00 41.9
VPWR($00) 14.062
VPWR($01) 13.800
ENG RUN($00) 11:51
ENG RUN($01) 11:37
OBD2 STAT($00) CA
OBD2 STAT($01) CA
When I do a scan on the "modules present", I get this:
$00 CAN(7E8)
$01 CAN(7E9)
Can someone help me understand? it looks like each module is reporting live data for each one.
Old May 25, 2009 | 12:29 PM
tcp's Avatar
tcp
Default A guess at best
I would think that the engine control module and transmission control module would both need access to the same information for proper action. Could those two modules be for the engine and trans? If so, polling them would give double the data. Is there some sort of "echo" setting on your scanner in the CANbus settings?
vader69
Jun 4, 2020 05:22 PM
vader69
Jul 19, 2011 06:49 PM
milankey
Sep 19, 2008 12:24 PM
allaflhollows
11
Aug 2, 2008 12:15 PM
itsmaheshp
Dec 3, 2007 06:49 AM
