Oil Change With Photos
Old May 28, 2012 | 09:49 PM
nesser's Avatar
Default Oil Change With Photos
Not a complete step-by-step instruction manual but I took some photos on Friday when I changed my oil.
Anyone have any suggestions for how to deal with the horizontally mounted oil filter?
What's the best way to get it off without making too much of a mess? I've read about others that are covering the starter (right below the oil filter) with a cloth or tinfoil but there isn't a lot of room to get in there to turn the filter and direct the oil stream at the same time.
http://amsoil.nesser.org/2012/05/mit...er-oil-change/
Old May 29, 2012 | 07:02 PM
Broncoman75's Avatar
Nesser,
I just changed my oil in the outtie for the first time last week, and I got the friggin splash of oil too. I had an acura before where the filter was mounted the same way, but it must have drained back into the block, because I don't remember getting dumped on when removing the filter... but I digress. I have not used one of these before, but might have to pick one of these form-a-funnels up for next time I change the oil.. that or just put a rag up there after I get it loosened
Form-A-Funnel® Flexible Draining Tool
Old May 29, 2012 | 10:00 PM
nesser's Avatar
I have the automotive one - you can see it rolled up in the tool box in one of the photos. I obviously don't have the dance right yet but I couldn't see or spin off the filter with the form-a-funnel in place cupped under the oil filter at the same time. So I spun the filter a bit and tried to jam the FAF in as fast as I could once I got some flow.
I'd choose the shorter lawn and garden version instead of the automotive style for the Outlander.
Old Jun 6, 2012 | 08:13 PM
benshepherd's Avatar
Changing the oil on the Outlander is a bit of a hassle compared to other cars for 2 reasons: The filter is not the easiest to reach and the dipstick is useless.
Re. how to deal with the horizontal filter, after draining the sump oil, I just unscrew filter slightly until oil dribbles out of the spout. Leave it for a few mins and most of the oil is gone. Not really particularly messy unless you rush it.
I never check the dipstick - I just drain all the oil, add the amount specified in the service manual and repeat 6000 miles later. Not ideal, but the dipstick is so unreliable.
mantis270
Dec 15, 2009 10:34 PM
wtf86
Aug 7, 2007 07:05 AM
microch
Jul 30, 2007 08:22 PM
raystevens90
May 29, 2007 07:58 AM
Trader4Less
Jan 16, 2005 04:04 PM
