Oil Change With Photos
Not a complete step-by-step instruction manual but I took some photos on Friday when I changed my oil.
Anyone have any suggestions for how to deal with the horizontally mounted oil filter?
What's the best way to get it off without making too much of a mess? I've read about others that are covering the starter (right below the oil filter) with a cloth or tinfoil but there isn't a lot of room to get in there to turn the filter and direct the oil stream at the same time.
http://amsoil.nesser.org/2012/05/mit...er-oil-change/
Nesser,
I just changed my oil in the outtie for the first time last week, and I got the friggin splash of oil too. I had an acura before where the filter was mounted the same way, but it must have drained back into the block, because I don't remember getting dumped on when removing the filter... but I digress. I have not used one of these before, but might have to pick one of these form-a-funnels up for next time I change the oil.. that or just put a rag up there after I get it loosened
Form-A-FunnelŽ Flexible Draining Tool
I'd choose the shorter lawn and garden version instead of the automotive style for the Outlander.
Changing the oil on the Outlander is a bit of a hassle compared to other cars for 2 reasons: The filter is not the easiest to reach and the dipstick is useless.
Re. how to deal with the horizontal filter, after draining the sump oil, I just unscrew filter slightly until oil dribbles out of the spout. Leave it for a few mins and most of the oil is gone. Not really particularly messy unless you rush it.
I never check the dipstick - I just drain all the oil, add the amount specified in the service manual and repeat 6000 miles later. Not ideal, but the dipstick is so unreliable.
mantis270
Dec 15, 2009 10:34 PM
2009, 2010, 2012, change, filter, horizontally, hot, location, mistubishi, mitsubishi, mounted, oil, outlander, replacement, v6
