Outlander 2007 Diesel 2.0 Crankshaft Sensor problem.
Old Jul 22, 2021 | 12:45 PM
simonrp's Avatar
Default Outlander 2007 Diesel 2.0 Crankshaft Sensor problem.
HI all - I am tearing whats left of my hair out with my Outlander. It's the 2.0 Diesel (the VW PD unit) - 2007 Elegance DiD. I am having Crankshaft Sensor problems.
When the car is completely cold it will start first turn of the key and perform normally for about 10 minutes. As soon as it gets hot the engine goes into limp mode and the Engine Management light comes on. OBDC shows as "Crankshaft Position Sensor A". When the car cools down (few hours) it will start fine again. If you try to re-start it when hot then it WILL start but you have to crank it about 20 times (and it will be in limp mode).
My mechanic has replaced the Crankshaft Sensor today and it's still exactly the same.
Before we have to go down the gearbox out route to replace the pickup does anyone have any ideas please ?
Thanks in advance.
Old Jul 31, 2021 | 12:20 PM
daem0n's Avatar
Have you read all error codes from ECU/transmission? What are they?
If there are no errors, it might be a bad cable/contact somewhere.... If your mechanic has a MUT-III then he must connect it and monitor/record some signals while starting and driving until the problem appear. Then there will be more chances to identify faulty cable/connection or unit.
Jes Bouet
Dec 19, 2022 03:33 PM
Gary DuBois
Jan 28, 2021 09:58 AM
Ivkovic
Dec 14, 2019 07:42 AM
cbreddie
Aug 3, 2019 03:31 PM
Rossy
Mar 8, 2017 02:26 AM
