Outlander 2007
Old May 14, 2019 | 12:42 AM
Jes Bouet's Avatar
Default Outlander 2007
Hey.
I have an outlander from 2007, a 2.0 diesel. It often goes into limp mode. I also think it uses a lot of diesel, I can only get it up to about 10 km/l or about 25 miles per gallon.
I just installed a brand new turbo when I thought it was the problem, but it didn't help anything.
Does anyone have a suggestion for what to try next?
Old May 14, 2019 | 05:11 PM
Matt101's Avatar
I have just had the same issue with my 2008. Turned out to be the Boost Pressure sensor. £25 from VAG. My average is now 44 to the gallon on a motorway run.
Old May 15, 2019 | 12:38 AM
Jes Bouet's Avatar
Thanks for reply.
Did your fuel consumption improve after the sensor was changed?
Do you know where it is located on the car?
Old May 15, 2019 | 11:22 AM
Matt101's Avatar
Hope this helps
Old May 15, 2019 | 11:23 AM
Matt101's Avatar
Originally Posted by Jes Bouet
Thanks for reply.
Yes and see above
Old May 16, 2019 | 02:47 PM
Jes Bouet's Avatar
Yes and see above
It helps a lot. I have now ordered such a sensor.
I hope this is the problem, because the engine will soon drive me crazy.
Old May 20, 2019 | 01:28 PM
Jes Bouet's Avatar
I have now changed the sensor, it has not changed anything.
I can still only get it up to 25 miles per gallon Max.
It smokes a lot when it accelerates, it must get too much diesel, or too little air?
Old May 20, 2019 | 02:26 PM
Matt101's Avatar
Have you got a code reader. Sounds like a fuelling issue. Especially the smoke part. I can ask my mechanic if he has any ideas he can throw your way
Old May 22, 2019 | 10:28 AM
Jes Bouet's Avatar
Yes I have had code reader on, there were no codes.
I have now changed the fuelfilter and airfilter, but also it was without result.
Old Dec 19, 2022 | 03:33 PM
asparkes07's Avatar
Hope this helps
Is this located under the battery from the top or do I need to get under the car? thanks
KayKay75
Jun 15, 2016 05:33 AM
jwaters943
Feb 14, 2007 11:31 AM
chelsel
Nov 27, 2006 04:57 PM
proutlander
Jan 18, 2006 10:17 AM
Richo
May 31, 2005 01:59 PM
