Outlander 2007 Rear Wheel Bearing
Old Feb 2, 2017 | 12:47 PM
raptornexus's Avatar
Default Outlander 2007 Rear Wheel Bearing
Hi guys how easy is it to change the rear wheel bearing/hub assembly on Mitsubishi Outlander 2007....is it straight forward or is it better to get a garage do it? thanks in advance.
Old Feb 2, 2017 | 03:58 PM
ccernst's Avatar
it is pretty straight forward. remove wheel, remove cotter pin for driveshaft nut, driveshaft nut, rear speed sensor (use wd-40 & patience), caliper assembly, brake rotor/disc, 4 bolts hold the new hub on. If you are not AWD, disregard anything driveshaft.
I have the service manual if you want it. shoot me a PM.
Old Feb 2, 2017 | 04:15 PM
Hi ccernst thanks for your reply...no its not AWD so sounds like an easy job....service manual would be a great help please
Smoked1
Jun 5, 2016 02:18 AM
nelsongg
Feb 28, 2016 11:31 PM
Dafatboy
Jul 14, 2015 06:06 PM
Rodney Hermanofski
Jun 15, 2015 01:34 PM
ultramindbrk
Dec 10, 2007 07:10 AM
