Outlander 2014 V6 and cold weather
Old Jan 26, 2015 | 12:49 PM
Rod Gurov's Avatar
Default Outlander 2014 V6 and cold weather
If somebody have / had same problems let me know:
temperature ( C) t < - 10 Sometimes my climate control not starting right away when I'm pressing button, but starting 10-15 minutes latter
Today Temperature < -20 and My car started normal, but did not drives, 3 lights went on Engine, Skidding control off, skidding control off. Eventually I start driving, but my car not accelerated, RPM < 1500, and speed < 50 km/h.
I made to service center, and "The Mechanic" "found battery fault" due to "low driving distance". Car is less than year old, I'm driving 2 hours per day 1 morning and 1 evening, enough to charge battery I guess ( otherwise it it sound ridicules that you have to drive you car to keep charge on battery ),
So any advises to "The Mechanic"
Old Jan 26, 2015 | 02:53 PM
ccernst's Avatar
hmmm, that isn't extreme cold...but cold enough it may be affecting the performance of your battery. a few weeks ago, it got down to -18c and the engine turned over slowly, but did start. Once started, it worked as normal.
your commute is more than enough to keep your battery charged.
The only thing I can think of is to have your battery tested. it is possible you have a low/dead cell.
Or you could have a failed alternator/voltage regulator and improperly charging your battery. I once had an alternator that worked as long as engine RPM was under 2500...above that, it didn't run correctly. Oddly enough, the tester at most parts stores here test at rpms that are comparably under 2500 engine rpms...so when I took it in for testing, it passed.
Old Apr 14, 2017 | 04:45 PM
Mark Denver Bautista's Avatar
i have a 2014 outlander v6 canada..it dont start unless i push down the accelarator then sometimes it start ok. but then after couple of hours it wont start again unless i give gas on it... any suggestion?
only 51k km..
roach
Feb 8, 2023 11:10 AM
tcp
Nov 11, 2008 07:52 AM
tcp
Mar 5, 2008 08:51 AM
Eclipse440
Jan 16, 2008 07:49 PM
_Adrian_
Dec 2, 2007 09:38 AM
