outlander
Old Apr 29, 2021 | 06:52 AM
PIP's Avatar
PIP
Default outlander injector removal
Hi does anyone know how the injector come out i have a leaking injector i have tryed to take it out but does the engine top cover need removing or does it just come out after removing the injector clamps thanks.
apologies it`s a 2011 4n14 egine 175 bhp 2.3 diesel thanks.
Old Apr 29, 2021 | 04:08 PM
DibbyDibbyDJ's Avatar
It would help if you told us what Model year, what fuel type, engine size and even engine code your car has......
Old Apr 30, 2021 | 05:26 AM
PIP's Avatar
PIP
right apologies it`s a 2011 4n14 egine 175 bhp 2.3 diesel
Old Apr 30, 2021 | 06:10 AM
After removing the 2 bolts on either side of the injector clamp the injector should come out easily. If it doesnt you will need some kind of puller to draw it out, but be careful, they are fragile and expensive. Do not twist it via the plastic plug on top. You can try to twist it via the section that the pipe screws into, but with not too much force. If it doesnt come loose, try refitting everything back, go for a drive to get it all hot, and quickly try again before it cools down... WD40 or another penetrating spray might help
Old Apr 30, 2021 | 07:14 AM
PIP's Avatar
PIP
okay thanks for the help
The Grocer
Mar 15, 2014 08:32 AM
danthe
Feb 6, 2014 04:44 PM
rishi_kapoor
Sep 14, 2010 02:10 AM
rcpax
Mar 28, 2007 10:13 AM
proutlander
Feb 12, 2004 12:42 PM
