Outlander has no power with CODES U0100 and P0657
Old Aug 8, 2020 | 02:08 PM
RickyBob's Avatar
Default Outlander has no power with CODES U0100 and P0657
I have a 2012 Outlander. My blower motor stopped working. So I went to fuse panel under the hood and pulled the ac fuse
after that the car started idling bad, the ACS needs maintenance code P0657 can up with U0100. I have no throttle car wont move in gear. The P0567 is throttle postion actuator relay. I switched relays. Nothing. I think I blew the ECM. I see in a diagram there is a 15 amp fusible link. Dont know where to look. Help...found the fuse. Not labeled but everything working except original problem of the blower motor not working
Old Aug 8, 2020 | 10:08 PM
ccernst's Avatar
What happens if you put the fuse back in? Just don't turn the fan on until you can have it looked at....no need to pull fuses.
Old Aug 9, 2020 | 02:07 PM
RickyBob's Avatar
Default Blower motor not working.
Is there a fuse for the blower motor. Mine will not come on for heat or AC.
tom61
Aug 6, 2016 10:50 AM
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
eclipse003g
Jul 8, 2009 04:00 PM
paintballproam
Jul 15, 2006 06:29 AM
