Outlander hesitates on take off
Old Mar 8, 2006 | 02:04 PM
royg's Avatar
Default Outlander hesitates on take off
I have a 04 outlander. 27,000 miles. I noticed in the past several weeks the engine will hesitate when taking off from a stop sign or light. It normally happens once after it is started and almost up to temperature. As you depress the throttle the engine speed does not pick up and it will almost stall and then take off. After it has done it once it will not do it again until after it has sat for several hours. Anybody else experience this problem?
Old Mar 8, 2006 | 05:04 PM
JMC's Avatar
JMC
Default RE: Outlander hesitates on take off
Wow.....I had this same type of problem with my Galant. I brought it in for a tune-up and it went away. I really don't know what it was. I could slam on the gas and it wouldn't go for a few seconds. Try going over all the basic things it could be and then I'd have it looked at just to be safe. Please let me know what happens.
Old Mar 8, 2006 | 05:38 PM
outlancer's Avatar
is it throwing a code? even if not, it could still have something stored on the memory and depending on where you are at you could get it checked at your local autozone for free. on a side note, at you current mileage +-5k is when i put new spark plugs in, it wouldnt hurt to try but i dont want you to be chasing loose ends with fixes that dont work all the time.
Old Mar 8, 2006 | 06:50 PM
wicked_outlander's Avatar
that happened to my eclipse, but i quickly change the stock spark plugs and re-set the e.c.u. the next day, my eclipse is runnin smooth.
Old Mar 9, 2006 | 12:44 PM
JMC's Avatar
JMC
Yeah....they must have changed the plugs!
Old Mar 9, 2006 | 11:10 PM
Punisher's Avatar
see but i thought our stock plugs were rated for 100k miles?
Old Mar 10, 2006 | 12:36 PM
JMC's Avatar
JMC
Yeah.......that's a great Mitsu line! WOO!
Old Mar 12, 2006 | 03:35 PM
dirtwagon's Avatar
I don't think I'd trust anything on my car for 100K miles, let alone a spark plug. But yes, they are supposed to be good for that long.
Hmmm, warrant item?lol....j/k.
What's the reccommendation from "those in the know" on a good plug, you know, the ones that give 20 extra horsepower...I'll be changing mine in a month or two, might as well start shopping. Oh yeah, I think I just blew a muffler bearing and steering wheel gasket. But at least I already got the major expense of replacing my rear leaf springs, a mechanic told me to.
Old Mar 12, 2006 | 03:36 PM
dirtwagon's Avatar
BTW, Roy, any luck?
Old Mar 13, 2006 | 12:24 PM
JMC's Avatar
JMC
YOU MUST CLICKY!
