Outlander hesitates on take off
Old Mar 30, 2006 | 01:43 PM
  #41
dirtwagon's Avatar
Default RE: Outlander hesitates on take off
Were you modding them too? Dumb question I'm sure. Did the galants have the same 2.4 or was it a V6?
Old Mar 30, 2006 | 05:32 PM
  #42
JMC's Avatar
JMC
first one was the 7th Gen.4 Cyl. Last one was a V6. Both had pretty heavy Mods....I miss the old Galant!
Old Mar 31, 2006 | 12:27 PM
  #43
dirtwagon's Avatar
7th gen 4 cyl is like telling me something in French, which I do not happen to understand. Can you offer me an education on this? What would the engine code be? The only thing I know so far is that the first number is the number of cylinders on the engine code.
Old Mar 31, 2006 | 12:40 PM
  #44
dirtwagon's Avatar
Never mind, too slow. j/k
Wonder if this is already sticky noted somewhere on the site and I just don't see it.
The number and lettering system of Mitsubishi engines can be a little confusing, so here is how to decipher them:
Numerical Prefix -
4 = four cylinder
6 = six cylinder
Numerical Suffix -
12 = 2.0 litre
13 = 2.5 litre
36 = 2.0 litre
54 = 2.6 litre
61 = 1.6 litre
62 = 1.85 litre
63 = 2.0 litre
64 = 2.4 litre
72 = 3.0 litre
73 = 2.5 litre
74 = 3.5 litre
91 = 1.5 litre
92 = 1.6 litre
93 = 1.8 litre
Sixes
http://img155.imageshack.us/img155/9292/03073lo4wn.jpg
The entire range of high performance Mitsubishi sixes is set in a V configuration. Starting off with the most powerful, the 6G72 twin turbo engine is responsible for pushing the heavy 3000GT/GTO to 100 km/h in around five seconds. Its attributes are a displacement of 3.0 litres, 8.0:1 compression, quad cams, 24 valves, twin (simultaneous) turbos, dual air-to-air intercoolers and a sophisticated EFI system - all giving a total output of 209kW at 6000 rpm, with a bag of 427Nm at only 2500 rpm! Now that would make one awesomely flexible road-car engine! In Japan, development of this engine has been quite minor in comparison to the Nissan RB26DETT, but we'd expect that you could attain around 300kW with simple exhaust, intake, intercooler and boost modifications.
A high performance naturally aspirated version of this engine (also called the 6G72), is available minus all the turbo intake trickery, but with a higher static compression ratio of 11.0 to help compensate. It makes 179kW at 5750 and 304Nm at 3500. A lower spec trim again can be found, which is good for 168kW and 275Nm, and yet another (as in the Japanese Diamante/Magna) is capable of 127kW and 248Nm.
About 17% larger at 3.5 litres, the DOHC 6G74 turbo comes suitable for front and all-wheel-drive and produces 194 kW at 6000 rpm.
http://img155.imageshack.us/img155/8499/03074lo4qr.jpg
The Japanese market Diamante is also powered by a 10.0:1 compression ratio atmospherically inducted 6G74 3.5 litre, that produces 194kW at 6000 and 324Nm at 4500 rpm. In between the 3.0 and 2.0 V6s is the 6G73 2.5 litre motor. Available in FWD atmo form only, this DOHC powerplant shares its basic design with the other engines in the 6G range, and is good for 131kW at 6000 revs.
A way - other than by turbocharging - that Mitsubishi has been able to develop big power from their engines has been through the use of the latest MIVEC (Mitsubishi Innovative Valve and Lift Electronic Control System) technology. This system employs a multi-mode variable valve timing mechanism set in three modes - low speed, high speed and MD (modulated displacement). The resulting optimised flow of gas through the heads enables these engines to deliver a substantial increase in torque across the entire rev range - but especially in the higher revs, where conventional engines are usually set with conservative valve lift and duration.
http://img155.imageshack.us/img155/7007/03075lo7uq.jpg
Displacing only 2 litres, the atmo MIVEC version of the 6A12 DOHC V6 with its 10.0:1 compression ratio is listed at an impressive 149kW at 7500 rpm and 200Nm at 6000. This engine is most widely-noted for its fitment to the sexy looking Mitsubishi FTO, which it powers from 0-100 km/h in under 8 seconds. There's also another atmo 6A12 engine (in either FWD or AWD configuration) that is the same as above but minus the MIVEC system and some compression points. It is capable of delivering a total of 127kW at lower revs
http://img155.imageshack.us/img155/5669/03071lo1vw.jpg
A turbo version of the non-MIVEC 6A12 engine was released too, which could pull 149kW - the same peak power as the wonderful atmo inducted MIVEC!
Fours
Mitsubishi's selection of four cylinders is where the company has earned the majority of its performance reputation.
One of the old-school engines Mitsubishi produced in the 80s is the SOHC injected G63B turbo. This engine came available in a number of different specs, but the most desirable is the 3 valves per cylinder 2 litre DASH engine which came in either FWD and RWD guise. This non-intercooled engine was able to stomp out a creditable 149kW at 6000 rpm and 280Nm of torque.
However, the more common version of this engine (also called the G63B) is the 2 valves per cylinder SOHC as found in the Starion/Conquest. This is still capable of a reasonable 131kW at 5500 rpm and 216Nm at 3500 rpm.
http://img155.imageshack.us/img155/7839/03076lo0ld.jpg
At about the same time (the early 80s) the Mitsubishi Cordia GSR hit the streets with very similar technology to the G63B - albeit in a smaller overall package, called the G62B. This 1.85 litre SOHC four was also non-intercooled (like most turbos of the time), and in the ultimate versions used a large capacity turbocharger to help it on the way to a maximum of 119kW at 5800 rpm and 216Nm at 3500.
http://img155.imageshack.us/img155/5827/03077lo8lc.jpg
The next generation of Mitsu fours was all based on the same blocks as those mentioned above, but sported DOHC heads to aid breathing. Amongst this late-80s group of engines is the front wheel drive 4G36 that came in some of the mid/compact size vehicles, sweeping a volume of 2.0 litres and producing 104kW at 6000 rpm.
One of the engines most widely used in competition (especially rally) is the DOHC 4G63 turbo engine. Available in a variety of specs, this engine comes in 2.0 litre capacity and is good for up to 209kW at 6500rpm, and 373Nm at 3000 in the Evolution 6.
http://img155.imageshack.us/img155/6918/03078lo7hp.jpg
http://img155.imageshack.us/img155/4144/03072lo3du.jpg
Released in both FWD and 4WD configurations, the double over head cam 4G93 atmo and turbo moves 1.8 litres, and generates 112kW at 6500 and 145kW at 6000 rpm respectively. One power-pack for the compact Japanese-spec Lancer GSR hatches was the 4G61 engine that pushed around 1.6 litres, used DOHCs and a single intercooled turbo to create a maximum of 108kW at 6000 revolutions. A smaller engine, the 1.5 litre DOHC 4G91, was a front-wheel-drive-only engine that was designed for use in hatchbacks, mustering up 86kW at 6000 revs with a peak of 137Nm of torque.
The latest MIVEC four cylinder is becoming quite popular in Japan (the only country where it is commercially available), and is an optional fitment to the Mirage, FTO and Lancer. The engine we're interested in here is the 1.6 litre 4G92 front wheel drive, that's good for an astounding 131 kW at a substantial 7500 revs per minute, plus 167Nm of torque at a sky-high 7000. This awesome little engine therefore has a specific power output of 81.8kW per litre - enough to rival even some of the best of the current turbo engines!
Mitsubishi performance motors at a glance...
Sixes
6G74 3.5 DOHC turbo
194kW
6G74 3.5 DOHC 194kW
6G72 3.0 DOHC twin turbo 209kW
6G72 3.0 DOHC 179kW/127kW
6G73 2.5 DOHC 131kW
6A12 2.0 DOHC MIVEC 149kW
6A12 2.0 DOHC turbo 149kW
6A12 2.0 DOHC 127kW
Fours
4G63 2.0 DOHC turbo 164kW
G63B DASH 2.0 SOHC 12 valve turbo 149kW
G63B 2.0 SOHC turbo 131kW
G62B 1.85 litre SOHC turbo 119kW
4G64 2.4 SOHC 108kW
G54B 2.6 SOHC turbo 131kW
4G91 1.5 DOHC 86kW
4G92 1.6 DOHC MIVEC 131kW
4G93 1.8 DOHC 112kW
4G93 1.8 DOHC turbo 145kW
4G36 2.0 DOHC 104kW
4G61 1.6 DOHC turbo 108kW
4g32 - 1600cc
4g33 - 1800cc
4g34 - 1400cc
MORE:
Example: 4G61T (1.6L I4 turbo motor in the Colt/Mirage turbo)
4 = 4-cylinder
G = Gasoline, Iron Block. (D = Diesel ie 4D65)
6 = Engine Series
1 = Engine Model (Doesn't equate to capacity, as a higher number can belong to a lesser cc'd engine.)
T = Turbo (This is more of an adopted addition
Old Mar 31, 2006 | 06:57 PM
  #45
JMC's Avatar
JMC
It was a 4G64 - 2.4L
Old Mar 31, 2006 | 07:47 PM
  #46
dirtwagon's Avatar
perhaps my last post should have been a bit more inclusive, it was kinda short huh? Aha... the heavier predecessor to the 4G69 without the new heads, cam control thingy and older intake style? I think I got one....hooray for me. j/k. You currently have a 4G64 right? Did anything get transplanted?
Old Apr 3, 2006 | 12:47 PM
  #47
JMC's Avatar
JMC
Maybe.........hahahahaha
Old Apr 3, 2006 | 07:01 PM
  #48
dirtwagon's Avatar
it's okay, you'll slip sooner or later.
  #49
dirtwagon's Avatar
so how's that throttle body working out anyway?
Old Apr 4, 2006 | 01:09 PM
  #50
JMC's Avatar
JMC
Have you done the simple throttle body mod yet??
Skyler888
Mar 3, 2011 08:45 PM
Anson02bugeye
Sep 4, 2009 10:00 PM
Spyder887
Jun 9, 2006 10:59 PM
95HGeclipse
May 29, 2006 02:26 AM
USCordia
Aug 13, 2005 05:57 PM
