Outlander Subwoofer
Old Jan 30, 2015 | 11:27 AM
CA51BEZ's Avatar
Lightbulb Outlander Subwoofer
Ho all
first may i apologize if this has been covered before i did a search but could not see anything.
I have a 2008 Outlander Warrior with no subwoofer fitted.
I have just purchase a subwoofer of fleebay,
will this just fit right in and are wires ect. already fitted
carl
Old Feb 1, 2015 | 10:27 AM
CA51BEZ's Avatar
Any info anyone
Old Feb 1, 2015 | 04:09 PM
danthe's Avatar
I believe that it can be installed only if you have rockford fosgate system with amplifier, but if you have that, than you would already have sub... so, it can be installed,but not easily
Old Feb 2, 2015 | 09:06 PM
copyboy311's Avatar
If you bought the OEM subwoofer that fits into the back corner of the Outlander, it probably won't be an easy plug-and-play setup. The factory system has an amplifier under the passenger seat that powers it. You have to start with that if it's the OEM Rockford Fosgate system you're talking about.
Old Feb 3, 2015 | 10:45 AM
CA51BEZ's Avatar
i just got the subwoofer i thought i just needed that as that was all seller had
Guess i will be selling it again
Old Feb 3, 2015 | 10:48 AM
CA51BEZ's Avatar
Hi
yes its the woofer that fits in back corner
it is the Rockford Fosgate woofer just thought i would need that as i got stereo in car
Dam guess i will be selling it again
Old Feb 3, 2015 | 01:18 PM
11SE2HEAR's Avatar
The Rockford Fosgate woofer assembly you have is a dual 1.1 Ohm woofer rated at 75WRMS on each coil. So you would need an external amplifier that delivers 150 Watts continuous at 2 Ohms (Rockford Fosgate PBR300X1 works good) if you don't currently have the Rockford Fosgate OEM upgraded amplifier under the passenger seat.
Old Feb 7, 2015 | 02:31 PM
rodsfromday's Avatar
I also bought this subwoofer. Its definitely not plug and play. I had an aftermarket double din unit in, so all i did was i ran complete new wiring for my pioneer amp and sub. I goes really good but the only issue i am still having, is some interference that i cannot seem to pinpoint.
11SE2HEAR
Jan 27, 2015 01:42 PM
rodsfromday
Jan 22, 2015 05:20 AM
armymen
Feb 8, 2008 02:09 PM
dr_max_facts
Jul 12, 2007 07:55 PM
Stealth691
Aug 18, 2005 04:01 AM
