Outlander Terrible Fuel Economy
Old Dec 15, 2013 | 07:29 PM
Rapaz_Simples's Avatar
Angry Outlander Terrible Fuel Economy
I just bought a new 2013 Outlander, and the fuel economy I am getting is terrible. I bought the 4 cylinders because the V6 required fuel premium, and this car is using more gas than a Hummer.
I have around 8000KMs on the car, 90% city drive, and 10% hwy.
I am only getting 15.5/100KM (city) and 10.5/100KM (HWY)... I am not driving fast (this car is slow like a turtle to move), the best I got was 9.6/100KM (HWY).
there is no day I regret most of buy this piece of junk.
I took to the dealer and they said the car engine will only break-in after 24.000KM. that's a big lie, and they even look at the car, that's probably the fuel economy stated by Mitusibishi is a big lie.
does this car can get better than this?
the engine is sooo underpowered, that this car can barely move after a stop sign.
Old Dec 15, 2013 | 09:53 PM
ivanz's Avatar
Does the temperature indicator ever go to the halfway point?
My 08 V6 gets 16 L/100km city (100% city) and I only drive for about 12 mins to/from work. On the highway, which I rarely go on, I've seen it down to 7.6 L/100km. Granted, that was during the summer.
Old Dec 16, 2013 | 07:46 AM
Vadimus's Avatar
V6 does not require premium, you just need it to meet declared performance numbers.
2.4 seems to be quite underpowered for Outlander, I guess nothing could be done about it...
Old Dec 16, 2013 | 09:58 AM
Guyfromhe's Avatar
4WD will kill your gas mileage as will driving hard which you may be doing because the weight.
I get pretty bad mileage on my '10 XLS but I like WOT a little too much :P I used to have a little Mazda so I am used to better mileage but even that I used to get to the higher number the mfgr specified.
My V6 I was getting about 16.6l/100km though my averages were lower (14.5 ish) when I was trying to drive sensibly but that never lasted a full tank of gas :P And with all the snow here now it's almost always transferring power so it's gone down a bit I just restarted my trip meter when I filled up yesterday so I will find out how I am doing in a few weeks when I fill er. (I don't drive very much)
Old Dec 16, 2013 | 07:51 PM
I usually drive 2WD most of the time. I tried premium and regular gas to avoid ethanol, and no improvements.
I also try to go light on speed, not going over 3000RPMs, and keep under 2000RPMs, and no improvements.
the other cars I had they were close to fuel economy stated. 350KM per 60L tank, that's too much.
I payed 37K on this car, checking for trade-in I can only get 20K, and only 8000KMs... there is no resale value on this car. this is my first and last Mitsubishi... if i spend this gas on a V6 that would be better, but a 4 cylinders we expect good fuel economy
Old Dec 16, 2013 | 11:02 PM
Guyfromhe's Avatar
There is no resale value on any new car... You loose at least 20 percent the second you drive off the lot. Try to get a lightly used car and you will save a ton of money...
I'd go back to the dealer about your fuel usage... It wouldn't be higher than my v6....
Old Dec 18, 2013 | 12:32 AM
Enzo's Avatar
Default same issues
looks like mitsubishi never really resolved this issue after all. I just got a 2009 2.4 es model and we have the same gas mileage. the only time i save on gas is when i don't use it, lol! i have been all around net researching for possible answers and solution and no luck. I guess i might just really be searching for nothing. it is very frustrating, and you are right i don't mind spending more for gas on a v6 but not a 2.4 with all the expectations that mitsubishi has been telling.
Old Dec 18, 2013 | 07:52 AM
Vadimus's Avatar
There's definitely something wrong with your car.
How do you calculate it? Is it Auto or Manual metering mode?
Old Dec 20, 2013 | 08:55 AM
Default calculation
on the odometer I set the trip A and B when I fill out the gas, when my car is on reserve, I can see I drove only 280KM, which is ridiculous number, I fill out the gas, and calculate the 60 - (new full tank)
this number is extremely awful, so I don't recommend this car to enemy
and I don't drive fast, if that be possible, this car move slow than a turtle...
Old Dec 20, 2013 | 09:57 AM
ccernst's Avatar
Rapaz, I need to chide in with everyone else. There is something wrong with the car and either needs to be returned or fixed.
