P0155 Oxygen sensor (front) heater
Old Jun 5, 2013 | 03:27 AM
ghia61's Avatar
Default P0155 Oxygen sensor (front) heater
Hello all,
I am a new member here, locating in Israel and own the MK1 Outlander 2007 2.4L petrol engine.
I got the check engine light on lately, and check for the code. I got the following code #:
CODE001:
P0155 Oxygen sensor (front) heater.
Does anyone can tell me which sensor should I replace?
Does Any one can tell me where do I find such a sensor?
Can I use replacement parts?
Thanks in advanced
Adir.
Old Jun 5, 2013 | 09:11 AM
ccernst's Avatar
Hey Adir, The oxygen sensor is sometimes called an O2 sensor. There are two of them for you, one before and one after the catalytic converter. The front one would probably be mounted on the exhaust manifold where it all combines down to one tube. Here in the states, you can get them from any parts store. If you use a socket to remove them, they make special sockets since there are wires that cannot be removed. I've used wrenches if possible.
Old Jun 5, 2013 | 10:11 AM
ghia61's Avatar
Thanks for the answer.
Some more information: the report called it Oxygen sensor2 (front) heater.
Does it say something more for you?
Do you have the exact P/N of this part?
Do you recommended some replacement or genuine one?
Here in Israel the original one is very expensive (about 500$ each), and I wonder if I can use replacement one instead.
Old Jun 5, 2013 | 11:50 AM
ccernst's Avatar
I'm sure a replacement part will work just as well. $500 is amazing. I don't know part numbers as I have a 3.0L engine. If you go to an auto parts store, you can look up the part number there.
mrbo
Jan 4, 2015 09:52 AM
softarno
Jan 2, 2015 08:38 PM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
3000gtyeah
Aug 17, 2005 08:22 PM
