Parking/handbrake adjustment
Old Feb 3, 2017 | 08:40 AM
kazlas's Avatar
Default Parking/handbrake adjustment
My driveway is uphill, so i always use parking brake. But lately i noticed its only holding my outlander if i pull all the way up. I checked my rear pads, they are worn, but not to the point that i have to change it. Is there a way to adjust handbrake?
2012 Outlander SE AWD 2.4L
Old Feb 3, 2017 | 11:18 AM
Jayasc's Avatar
If the pads are still good, then maybe you just need to take some extra slack out. When you take the rear wheels off, you should see a rubber plug at the bottom of the rotors. Pull the plug out and you should be able to see the adjuster for the parking brake. Use a flat-tipped screw driver to turn the adjuster.
I forget which way to turn it, but turn it until the pads touch the rotor, so the disc scrapes or won't turn AND then turn the adjuster back 5 notches.
When you put the wheels back on, they should spin freely and the parking brake lever should only have to be raised a little bit to set the brakes now.
Old Feb 3, 2017 | 11:38 AM
ccernst's Avatar
Be carefull you are looking at the right correct pads. Emergency brakes are actually on the inner side of the rear brake disc. The brake disc resembles a top hat. Emergency brake hardware resides on the inside and uses the top hat piece like a drum.
Here is a link to the emergency brake shoes/pads.
http://www.rockauto.com/en/emailpagetofriend.php?ni=425
to inspect, you'll have to remove the wheel and probably the rotor/disc.
Natedogg89
May 30, 2017 03:07 AM
playdoh1130
Dec 14, 2014 09:45 AM
skipperx
Mar 26, 2012 07:00 AM
Vetter
Nov 22, 2004 10:44 AM
Lefty
May 27, 2004 03:43 PM
