pcv crankcase breather valve
Old Jan 24, 2022 | 07:17 AM
kokodream's Avatar
Default pcv crankcase breather valve
Hello,
Need your help and advice:
Mitsubishi outlander 2.0 di-d /2008 model
Found my pcv crankcase breather valve failed. It's stay open,oils around pipe and oil gases come to the coupe.
I updated 2 photos.
Can I open the pcv crankcase breather valve cover and replace the valve?
If yes ,what tools to use?
Thanks
Old Mar 12, 2023 | 06:59 AM
Darkman1961's Avatar
I got the smell of fumes in cabin when at a stand still .same problem my is 2009 .did you find out what you need to do ? which is the valve ?
Old Mar 12, 2023 | 10:25 AM
kokodream's Avatar
Hello,
It's not from pcv crankcase breather valve. Actually I found it's from EGR cooler, the pipe wich is connected to exhaust, gasket was burned and exhaust go through the engine room and from ventilation sistem through cabin.
I hope this will help you.
Old Mar 12, 2023 | 01:18 PM
Can you put a picture up please of were it is .thank you.
Old Mar 13, 2023 | 02:00 AM
kokodream's Avatar
I sold it last year and can't take a shot.
But I updated photos, what is look like the EGR cooler,some of the pipes is corroded or gaskets. I cleaned few times this cooler, usually get blocked easy.
EGR it's terrible sistem for auto owner.
Old Mar 13, 2023 | 01:45 PM
Thank you I will check mine and see if that makes any difference .
Old Mar 15, 2023 | 01:42 AM
plivacasce's Avatar
Arrow 1
where can i buy pipe and membrane
Old Mar 15, 2023 | 01:44 AM
plivacasce's Avatar
Default where can i buy pipe and membrane
kokodream
Jan 26, 2022 05:10 AM
trident
Jan 29, 2007 09:07 PM
Missile
Nov 26, 2006 10:48 PM
tiger13
Apr 13, 2006 01:31 AM
popatop
Dec 10, 2004 11:48 PM
