Hello,
Need your help and advice:
Mitsubishi outlander 2.0 di-d /2008 model
Found my pcv crankcase breather valve failed. It's stay open,oils around pipe and oil gases come to the coupe.
I updated 2 photos.
Can I open the pcv crankcase breather valve cover and replace the valve?
If yes ,what tools to use?
Thanks
Hello,
It's not from pcv crankcase breather valve. Actually I found it's from EGR cooler, the pipe wich is connected to exhaust, gasket was burned and exhaust go through the engine room and from ventilation sistem through cabin.
I hope this will help you.
I sold it last year and can't take a shot.
But I updated photos, what is look like the EGR cooler,some of the pipes is corroded or gaskets. I cleaned few times this cooler, usually get blocked easy.
EGR it's terrible sistem for auto owner.
