pioneer f900bt fitting questions
Old 05-26-2009 | 10:26 AM
james gaunt's Avatar
Default pioneer f900bt fitting questions
Hi i have a euro Mitsubishi outlander equivalent (the Peugeot 4007) i have some questions before i attempt to fit my new pioneer f900bt.
i have the bog standard 6 disk cd changer ie no amp.
i have the pioneer steering wheel controls adapter (ca-r-pi138)
i have several questions
1) how do i access the handbrake switch?(with pictures if possible)
2) where is the best place for the gps antenna? (preferably inside the car)
3) how do i connect a speed sensor cable?
i will post pictures of my install which i intend to complete next week.
any help greatly appreciated many thanks!
Old 05-27-2009 | 12:25 PM
tcp's Avatar
tcp
Default Why not bypass all that
To enable video and entering GPS address while the parking brake is disengaged, you need to do the following:
From WIRE SIDE of small white plug
-Mute wire (YEL/BLK) is in upper row, left pin
-Move this wire to lower row, 4th pin from the left (empty pin between 2 black wires)
-Ground YEL/BLK & LT GRN (Brake wire)
Check out www.avic411.com for more info on this unit.
I think this will allow the movie to play during driving as well.
Old 06-20-2009 | 12:34 PM
xOutlanderFiendx's Avatar
i deff want that same system for my 09 outlanderr ! i just wonder if it will fit?.. even if i have to convert it.. can it be done?.. i would like to see if i can do it myself rather than pay someone.. whats the update on your car james gaunt ?
nieves74
08-13-2009 09:26 AM
antlip
05-16-2007 03:30 PM
spikydave69
09-16-2006 04:45 PM
6stang7
12-15-2005 10:35 PM
SkavolutionMMB
08-21-2004 07:40 PM
Quick Reply: pioneer f900bt fitting questions
