Poor radio signal on Outlander 2007 Help!
Old 08-07-2011 | 03:09 PM
Brucy2000b's Avatar
Default Poor radio signal on Outlander 2007 Help!
I have a 2007 Outlander with a stock radio single CD player installed. I am constantly getting the radio station breaking up and another one cutting in. Any Ideas? Oh and I have always had excellent signal coverage in my past cars
I was going to get a in-line areal booster but need to know where the Antenna remote switch to activate it would be?
Old 08-07-2011 | 06:59 PM
GREG's Avatar
Question
Have you done or had any work done to disturb the antenna connection to your radio? Does the cutting out happen on ALL of your stations?
Old 08-08-2011 | 04:49 AM
Brucy2000b's Avatar
Yes all stations mate and I have checked all connections too they are connected ok
Old 08-13-2011 | 07:59 AM
OutDave07's Avatar
i have the same problem
Old 08-13-2011 | 08:27 AM
Vadimus's Avatar
+1
Sound often drops from stereo to mono.
Old 08-18-2011 | 03:38 PM
noel55's Avatar
my AM radio drops around 5:00 pm when the stations lower power. I never had this problem before with a car. Any advice
Old 08-24-2011 | 12:45 PM
Ian's Avatar
Ian
I have a 2009 outlander and the sound often drops from stereo to mono.
The antenna is not the problem, is the poor quality of the mitsubishi radio.
This is probably the Mitsubishi engineer who wanted it, this is probably
because they want everyone to subscribe to Sirius radio !!
Old 09-24-2012 | 04:22 AM
kentg01's Avatar
hi i also have a 2007 outlander with the same problem, have you managed to find out what the problem is
Old 09-24-2012 | 11:00 AM
tcp's Avatar
tcp
Default It's the radio
The tuner of the stock radio is very poor. Either the single or 6disk stock units have terrible reception. I've replaced mine with a pioneer DVD unit and the reception is perfect now using the stock antenna and wiring. Not much you can do if you want to stick with the stock system.
Old 09-24-2012 | 11:59 PM
ivanz's Avatar
Yes replace the OEM stereo, its garbage for reception. I bought a cheap 2din stereo and it blows the OEM one out of the water for everything (FM and CD/MP3).
Outlanderishness
10-20-2019 06:09 PM
Outlander jake
02-16-2015 01:27 PM
bikerville
04-05-2009 09:34 PM
rosetex
12-08-2008 07:14 PM
Exist
12-26-2006 05:24 AM
