Power steering leak
Old Jun 22, 2020 | 02:20 PM
copyboy311's Avatar
Default Power steering leak
Anyone had power steering leaks on the second generation Outlander (2007-2013)? I just noticed a leak that's collecting on the right frame rail behind the tire. I noticed when most of the fluid had leaked out and the pump started making noise. Refilled it and noise subsided, but the leak needs to be fixed. Not something I'd attempt myself, just wondering if there's a common fail on these. Pump? Hose? Steering rack? What would be most likely the failure if the fluid is collecting on the frame rail? I just need a few more months out of this car before I sell it. It's been good, but 167k miles is enough.
Old Jun 23, 2020 | 01:46 PM
copyboy311's Avatar
Got it fixed. It was just a clamp on the hose that had failed and started leaking. I was worried I'd be looking at a new PS pump, or worse, a steering rack rebuild. All in all, in the 10 years I've owned this Outlander, it's been pretty solidly reliable. Age-related things needed replacing like the radiator, suspension and exhaust, but it's otherwise been good. It's given me less trouble than most of the four Subarus I've owned. Still almost no rust on the body despite salty winter driving. Just a couple spots on door seams that I've cleaned up.
wired4sounds
Sep 12, 2021 02:53 AM
1960StudebakerHawk
Mar 15, 2020 05:12 PM
Outi2006
Mar 13, 2011 10:46 AM
max3
Feb 15, 2008 12:15 AM
TheAdvocate
Mar 17, 2007 06:04 PM
