Problem with A/C blower.
Old Mar 23, 2014 | 10:41 AM
Michael Munoz's Avatar
Default Problem with A/C blower.
Hello, I have a 2008 Outlander. My a/c blower stopped working the other night. I pulled the blower out and it was shot. The bearings were gone, it was obvious by the handful of bearing dust that few out. I replaced the blower, checked all fuses and relays, even swapped them with known working ones. Blower still won't run. I checked for voltage at the blower and got 10.5 on low and 5 on high. which seems backwards to me. I havent replaced the resistor pack yet. I'm out of town right now but will put power direct to the blower when i get home just to make sure. also the old blower would spin with direct power but you could hear the damaged bearing so i just swapped it. Any insights?
also i dont know if there are different switch setups for other models but my fan speed is controlled by the center of three *****. it has a board selection of speeds not just low medium and high.
Figures just as I paid the car off something would go out.
Old Jul 25, 2023 | 05:22 PM
outlander2011mitsubishi's Avatar
Hello,
Did you ever fix this, I have exact same problem.
Thanks
Old Jul 26, 2023 | 05:37 AM
It was indeed the transistor pack. Replaced it and it worked fine.
Drewbiedoo
Jan 10, 2014 07:11 PM
goose1970
Jul 4, 2013 02:31 PM
dlbrownfshs
Apr 10, 2011 10:35 AM
imchief
Aug 22, 2010 10:08 AM
Razor
Jul 14, 2009 04:44 PM
