radio killing battery
Old Nov 18, 2015 | 05:04 PM
Here2Learn's Avatar
Default radio killing battery
2008 xls, battery dieing withing 24 hours, did the resistor test to find the parasitic drain and found out the stock 2008 rockford radio is drawing 3 volts with key off. the radio itself is also off (well the display and sound anyway) but if I pull the 15amp radio fuse under dash the drain stops. sorry I do not know how many amps its drawing as i only have a volt meter and did the resistor test. any ideas?
Old Nov 18, 2015 | 10:08 PM
Guyfromhe's Avatar
I wouldn't expect to see 3 volts at the radio when it's off.. And if it's killing your battery in a day there's a problem...
Does the battery stay good if you leave the radio fuse out? Are any other systems affected?
Did you disconnect the battery and let everything reset?
I would probably pull the head unit out and see if the drain is gone... If that's the case a new HU is pretty cheap online or at a junk yard.
Old Nov 19, 2015 | 07:39 AM
Here2Learn's Avatar
3 volts go away after radio fuse is pulled, i dont know exactly how the resistance test works I just know the battery draw stopped after pulling that fuse.
battery is fine and lasts for... ~ as long as that fuse remains out.
This did start happening after I disconnected the battery to remove the drivers airbag.
Old Nov 19, 2015 | 09:07 AM
Guyfromhe's Avatar
Have you removed the battery again since then?
That's a strange problem to start happening like that...
Old Nov 19, 2015 | 11:13 AM
Here2Learn's Avatar
Yes, the battery has been connected and disconnected 3 times in total. I'm going to try and get ahold of a DC amp meter to get a better reading.
Old Nov 26, 2015 | 12:36 AM
Here2Learn's Avatar
okay so the radio alone with key off is drawing 2 amps per hour. ive been searching forums and the most ive found is a diode "leaking" voltage from the memory draw. guess its time for a new radio...
Old Nov 26, 2015 | 08:42 AM
Guyfromhe's Avatar
Looks like they are about $75-100 on eBay... I would call some local scrap yards you might get a better deal.
Old Nov 26, 2015 | 09:10 PM
Here2Learn's Avatar
I pulled the radio today and with it disconnected and out there is still a draw on that fuse so I tested the fuse to ground for continuity and everything checked out fine.. Is there something else on the radio fuse? It is fuse 7 and it's a 15 amp fuse under the dash. I looked in repair manual and couldn't find a fuse description diagram.
** so according to a Mitsubishi dealer that fuse also powers bluetooth and navigation, and I have neither of them... again with radio out there is still a draw on that fuse.
Old Nov 29, 2015 | 03:04 PM
Here2Learn's Avatar
Okay so its fixed now.. it was the bluetooth module I didnt think I had, the buttons on the steering wheel hasnt worked since I got the car so I thought I didnt have the module, looking down in behind the radio I saw it mounted and disconnected it and the drain is gone. thanks for taking the time to read my posts.
second note, behind the radio is a harness that is taped up and out of the way, any idea what that goes to?
Old Nov 30, 2015 | 08:50 AM
Guyfromhe's Avatar
Good that you found it.
I'm not 100% sure but I think that harness might be for the MMCs.
