Rear (back side door) windows on 07 XLS
Old Aug 19, 2008 | 02:25 PM
chenarm's Avatar
Default RE: Rear (back side door) windows on 07 XLS
If you don't think it's a common problem try this.
When you lower the rear windows it will tilt backward about halfway down;lower the window until is flips back and then raise the window.
When I do this on my car, as the windowlevels out (going up), on the passenger side it pinches the trim all the time, and once in a while it will jam. On the driver's side it jams almost all the time.
I'm attaching a couple of pics of what happens on the drivers side.
[IMG]local://upfiles/15238/14BC54A9EED74B35859411E2CD0CB226.jpg[/IMG]
[IMG]local://upfiles/15238/6F67B668FB674F43A2993A3C7DD40A3F.jpg[/IMG]
Old Aug 19, 2008 | 03:37 PM
klas's Avatar
Where are you located?
My Outlader is in US, I think manufactured in February 07.
I tried to reproduce this issue and I failed
Old Aug 19, 2008 | 10:21 PM
rancho66's Avatar
If it has happened to more thanthree vehicles in this forum I would put it in the "common" problem category for our Outlander...but I amnot losing any sleep over the window problem as I am quite happy with the decision to buy my LS (US Vehicle)! I could start posting all the good points (MPG, Engine, Transmission, stereo, etc), but finding out about other owners with my same problems and how the dealers fix the problemsis what I look for in this forum. I will post how the dealer handles my window tomorrow for those that care.
Old Aug 21, 2008 | 07:26 AM
chenarm's Avatar
I took the car to the dealer yesterday, all they did was put some lube in the track for the window, it seem to help. However I'm a little concern that the lube will eventually loose it's effect, not to mention that the edge of the window now greasy.
The also ordered a replacement track, molding, seal, what ever it's called, since the current one got cut by the window when it got jammed.
Old Aug 21, 2008 | 08:30 AM
rancho66's Avatar
The dealer finalized my third trip for the right rear window problem. I have new run channels (replaced twice), regulator, rubber seal, and the door sash (Applique) that was damaged by the window coming out of the seal. The window seems to be a little less loose when I wiggle it. Hopefully this will fix the problem.The dealer gave me a copy of what the cost would have been if not under warranty: $333.69 ... thank you Mitsubishi for covering the tab!
NEW subject: Any of you cold weather Outlanders had this TSB performed? My heater last winter was a little on the cold side as I remember.
Make : MITSUBISHI
Model : OUTLANDER
Year : 2007
Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC.
Service Bulletin Number : 040108
Date of Bulletin : APR 01, 2008
NHTSA Item Number : 10024796
Component : ELECTRICAL SYSTEM: SOFTWARE
Summary :
ENGINE CONTROL MODULE REPROGRAMMING FOR POOR HEATER PERFORMANCE. *NJ
Outlander-RY
Sep 1, 2015 09:31 AM
rbomb42
Apr 14, 2012 09:01 PM
colomonty
Jun 29, 2010 09:10 AM
bishigt_18
Nov 1, 2008 07:24 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
