Replacement brakes for the 2nd Gen Outlander
Old Jun 6, 2007 | 08:38 PM
fkadir's Avatar
Default Replacement brakes for the 2nd Gen Outlander
Hi Guys, I have just received the new Outlander and dunt really like the spongy feel of the brakes.
Thinking of replacing the stock brakes. Are there any compatible brake-sets from Brembo?
Thanks!
Old Jun 6, 2007 | 09:36 PM
OTO27's Avatar
Default RE: Replacement brakes for the 2nd Gen Outlander
I dont think the brakes are supposed to be spongy, I would get the dealer to bleed them for you,although some brembos with big rotors would look sick.
Old Jun 6, 2007 | 10:44 PM
fkadir's Avatar
Yeah, looking for that sick look indeed. Big rotors and that infamous caliper probably in black to match my car's color or maybe red if I want it to really stand out.
Old Jun 6, 2007 | 11:28 PM
OTO27's Avatar
This is defenetlly in my to do list for future mods that will not void your warranty. The way I see it you have to make your car stop fast before it can be fast.lol.
Old Jun 6, 2007 | 11:31 PM
fkadir's Avatar
So the question remains... Brembo have compatible brake-kits for the Outlander? Or can we use the brake-kits meant for the EVOs?
Old Jun 7, 2007 | 12:03 AM
OTO27's Avatar
The "evolander" had brembos in them, so I'm sure theres a set out there that works, its just a matter of finding out, may be you should give them a call and ask.
*EDIT* Now you do know you just can't bolt on a bigger caliper and rotor without changing the stock master cylinder right? so thats another thing you have make sure is available for our cars.
Old Jun 7, 2007 | 06:51 AM
antlip's Avatar
Spongy.... mine are touchy as hell. If you touch mine alittle too quick you get a good jerk.
Old Jun 7, 2007 | 08:26 AM
bnilguy's Avatar
I think the stock brakes are darn good as far as feel..something must be wrong
Sponginess would be from air in the line or a line that flexes under pressure
Old Jun 7, 2007 | 07:44 PM
fkadir's Avatar
OK, will bleed the lines and maybe replace the brake hose to steel-braided just to have a better feel when braking.
Old Jun 7, 2007 | 09:31 PM
BoldlyGoingNowhere's Avatar
Really if theyre bad enough you think you need to change the lines you definately have some problem either there is a problem with the vehicle or you havent driven enough vehicles or your doing something out of the ordinary. like towing max weight without trailer brakes?
Are you a left foot braker?
I ask this because I have 5 vehicles, and 2 motorcycles it has been difficult not to put myself through the windshield when I brake the outie.
If you just want to add bling please dont blame it on the brakes.
