Roof mounted flip down DVD player
I have looked in the cavity between the inner lining and the sun roof and there seems nothing to bolt to, mitsubishi will probably want an arm and a leg for there unit, not to mention the fitting, I was hoping to buy one somewhere else and fit it myself, if you get anything from the dealer here in the UK they usually take your eyeballs out
Is yours the second gen outlander? I have an 07 LS with the sound and sun package and yes it does have the dvd on the roof right behind the sunroof. The dvd itself is well over a thousand dollars from the dealer......install probably not included.
In the case of RES, the installation isn't complicated, perhaps yourself could install it, in the case of dvd aftermarket, the better option is a installer
I have a UK Outlander with a Mitsubishi fitted unit. The unit they install is the overhead system made by Rosen.
You might be able to source one through another supplier and save on the dealer mark up.
http://www.rosenentertainment.com/index.htm
Found the unit for £149.99 at the below web site.
http://www.caraudiocentre.co.uk/prod...a7_p-22533.htm
https://mitsubishiforum.com/forum/sh...highlight=jsrd
mehr_ak
10-13-2013 01:34 PM
RCJr9186
11-09-2006 10:32 AM
RCJr9186
10-23-2006 04:36 PM
