Satellite Radio Question (XM)
Old Dec 25, 2010 | 08:39 PM
FloydTheBarber's Avatar
Default Satellite Radio Question (XM)
I purchased an Audiovox onyX Receiver & Car Kit (http://www.myradiostore.com/xm-radio...vers/onyx.html) and installed it using the PowerConnect (which plays the audio through an empty FM channel).
The reception was reasonable and I was fine with it, but the drop/dead zones were driving me nuts.
So I purchased the Sirius XM FM Direct Adapter/Modulator (http://www.myradiostore.com/fmmodula...ifmmore14.html) hoping this would solve my problem.
I'll add that I have an '08 LS w/o Rockford Fosgate and single disc unit. Installation was easy, and although I haven't driven it yet to test if this will reduce my dead zone issue, my real questions are:
My Onyx gets no XM reception without the original XM Magnetic Mount antenna plugged in with my FM Direct Adapter. I thought the Adapter was supposed to reduce the need of using the original XM antenna. And ONLY use my vehicles own antenna.
Perhaps I didn't install it properly? Although, all AM and FM radio stations work fine, and with the FM adapter plugged in (just in my driveway so far), it does seem to get a tiny bit more clarity.
Also, did I assume wrong? Will this even solve my drop zone issue? Or is it just for more clarity? FYI, I live in Vancouver, BC if that makes any difference.
Any help? Looking at the myradiostores notes, it says that I may need an additional adapter for my car, but they don't have anything listed for Mitsubishi. So I assumed I wouldn't need anything else.
Thanks in advance.
gossamer
4th Generation
Nov 28, 2010 10:24 PM
jw6594
Sep 22, 2009 10:24 AM
joe603
Jun 18, 2009 03:10 PM
rdenis
Jun 26, 2007 09:36 PM
Moontero
Mar 5, 2005 02:14 PM
