Seeking some Help/Advice on rear shock replacement
Old Apr 19, 2018 | 09:32 PM
teredactle's Avatar
Default Seeking some Help/Advice on rear shock replacement
Hi Gang,
My wife's car needs the rear shocks replaced (according to the stealership); I don't see any sign of leakage, but they told her they need to be replaced. They gave her a cost of $175 + 1.5 hours of work, that is per shock. So total around around $650+Tax (Canadian).
I have done some major work on my old 2000 Cherokee sport, and I get that the outlander is not quite as simple to work on (access, ease of removal, etc).
I found these on Amazon (first search):
https://www.amazon.ca/dp/B009HU5H3Y/...=1CKLWGX4GZ2C9 https://www.amazon.ca/dp/B009HU5H3Y/...=1CKLWGX4GZ2C9
which are a fit for her 2011 Outlander, however it's not clear to me if there is a need to purchase anything additional to them (like any kind of bushings, accessories, bolts, etc... that will be required when changing these out).
>Hoping to get your advice on that.
I have not been able to find any writeups on the replacement process. (removed link to wrong video)
Any help would be appreciated.
thank you
Old Apr 19, 2018 | 10:33 PM
ccernst's Avatar
Kyb are oem shocks
Old Apr 22, 2018 | 08:32 AM
teredactle's Avatar
Bump, *anyone*?
It looks like the video above that I found is not the same as on the Outlander (edited post). I just changed the tires to summer one yesterday and noticed that the strut is not inside the coil spring, it's a separate assembly, so replacing it may be easier than replacing one where it's inside the spring.
Anyone have a write up on this, or a guide, video link etc?
Thanks
Old Apr 23, 2018 | 03:11 PM
WHITEOUT2010's Avatar
Default Rockauto.com
Buy them here. Never failed me.
n.w.m
Jul 16, 2017 12:09 PM
Outlander-RY
Feb 12, 2017 08:10 PM
Outlander-RY
Feb 11, 2017 03:27 PM
Stephen Pierson
Jun 11, 2016 05:16 PM
ictponder
Oct 15, 2007 10:11 PM
