"Service Required" indicator on dash board
Old Oct 22, 2012 | 12:58 PM
GPSeek's Avatar
Smile "Service Required" indicator on dash board
I just got a "Service Required" warning on the dash board console.
It is a 2007 XLS with Navi.
Please refer to the picture. Anybody experienced this before?
What is this? releated to TPMS sensors?
Thanks!
Old Oct 22, 2012 | 01:38 PM
Claude_A's Avatar
The owner manual is a good starting point.
I would say you need a new battery in your remote key.
Old Oct 22, 2012 | 04:02 PM
GPSeek's Avatar
Thumbs up
I did what you suggested and here is on page 3-25 as attached.
You're right that it is about the remote key. However, it does not seem to be the battery. I did get the "Key Low Battery" error messages several times in the past and fixed the problem by simply replacing the battery.
The "Service Required" error messages are sporadic. I'll do a battery change if this does not go away tomorrow.
Thanks!
Old Oct 22, 2012 | 07:17 PM
Vadimus's Avatar
GPSeek, if you're in GTA I can read what exactly wrong is with your immo ECU.
Old Oct 22, 2012 | 11:34 PM
GPSeek's Avatar
Smile
Thanks, Vadimus.
I googled GTA and found out it is Toronto area. That is 500 miles from tristate area.
I was quite close to Toronto this summer, driving to Niagara Falls, ON with my 07 Outlander.
Thank you again fort your kindness.
Old Oct 23, 2012 | 02:21 AM
Burtonrider10022's Avatar
Originally Posted by GPSeek
Thanks, Vadimus.
If you update your profile with your location there may be other local members who can help you.
Old Oct 23, 2012 | 08:27 AM
ccernst's Avatar
you can go to an auto parts store and rent/borrow an OBDII/CAN reader to get the code. once we have that, we can start digging into what is happening.
Old Nov 6, 2012 | 09:59 PM
GPSeek's Avatar
Exclamation An update
Here is an update to this error message.
Now I think this error message is really a warning for the real battery, the lead battery under the hood!
I come into this conclusion because I also ran into startup issues last week and finally had to replace the lead battery on Sunday night to get the car started.
I see no more such error messages for the last 2 days.
The battery that came with the car lasted for 5.5 years and 92K miles.
How long did your OEM batter last?
Old Nov 7, 2012 | 12:13 AM
ccernst's Avatar
I replaced mine this summer. a bit over a year ago I opened the old battery up and noticed the acid level was low in several cells.
Old Nov 7, 2012 | 02:13 PM
copyboy311's Avatar
Mine's still going (a 2007 XLS), but I can hear it starting to struggle on cold mornings, and I figure it will die this winter at some (inconvenient) point.
