Size of drain plug for transfer case and rear differential on 2016?
Anyone know the size of the drain plug for the transfer case and rear differential on a 2016 Outlander? Fill size would be good too if you have it? Probably take it to the dealer for the CVT change so they can reset the computer.
Here is a link to a thread that mentions the size of wrench to use on 2010 Outlanders with SAWC. Maybe your vehicle has the same size plug, maybe not. If your vehicle's arrangement is the same, get ready for a bit of a struggle to change fluid. I highly recommend that you raise the vehicle as high as possible while still having the vehicle level. Maybe two sets of jack stands.
https://mitsubishiforum.com/forum/mi...-fluids-53326/
hila
10-06-2017 07:27 PM
rayf01
03-04-2014 03:00 PM
