Slow Down warning Light on 2008 Mitsubishi Outlander 2.4 MIVEC with CVT Transmission
Old Nov 3, 2015 | 01:24 PM
  #21
Sacky Shivute's Avatar
I love the car to bits but this cvt issue is seriously annoying.
Old Nov 5, 2015 | 12:26 AM
  #22
niazqamar's Avatar
Sacky Shivute, where are u from? Namibia?
Old Nov 5, 2015 | 01:21 AM
  #23
niazqamar's Avatar
@ Sacky Shivute: Mechanic for Windhoek .Dula +264813768154, Marco Auto Clinic +264811272479, Tommy Lombard (Okahandja) +264812964245. For Transmission: Gear box and diff doctor (Anton) 061-227104.
Remove sump, let the old oil drain completely, clean filter, Anton might have a machine to suck the old oil out and put new oil (Mitsubishi CVT J1).
Old Nov 28, 2015 | 09:57 PM
  #24
ah2hamed's Avatar
Default Tip tonic shift always shows 5 and not moving
I have problem with my outlander 2008
yesterday while driving for a short distance i get service required wronging alarm and car sound it became very high and transmission very hard, then i tried to shift the gear to tip tonic the shift always shows 5 on the screen and the shift doesn't change from 5 to 4,3,2 or 1 and vice versa
after that i have to stop the car more than an hour but the problem still same.
Please help
Old Feb 18, 2017 | 12:34 AM
  #25
carlitoslam's Avatar
Stay away of CVT transmission
My Outlander started having CVT issues after 130,000km
It cost me $6000 to fix it
CVT is very weak and won't last compare to the normal automatic transmission.
Old Jan 5, 2021 | 03:29 AM
  #26
David Kinoti's Avatar
Originally Posted by niazqamar
Dear All,
I recently bought a 2008 Model Mitsubishi Outlander 2.4 MIVEC Engine with CVT Transmission. The car is ex Japan Import. on one previous trip to a costal town which is 400 KMs from where i stay, the car gave with the above mentioned warning on our return. I slowed down and the warning went. We drove slowly home and the car didn't show the warning again. Day before yesterday, i also drove on the same highway and after almost 100KM drive the car gave the same warning as per attached picture. i slowed down and it disappeared. I drove normally and the light didn't come back. It came on once on the way back. Please help. I had taken to a local mechanic last time and his diagnostic machine didn't through any fault codes
I had a similar issue. Solution: install an transmission cooler. You will need to change the existing heat exchanger with one that has 4 outlets.
Old Apr 27, 2022 | 08:22 AM
  #27
Anuj's Avatar
Default Paper filter for cvt fluid
Hi, i guess you would have cleaned the metal filter for the cvt fluid which is inside the oil pan during the fluid change, did you also change the paper filter which filters the fluid which goes into the oil cooler... If this paper filter is old and clogged then circulation into the cvt oil cooler would get restricted and oil would get hotter. Hope it helped.
Outie_NZ
Jan 25, 2025 05:55 AM
niazqamar
Apr 18, 2018 10:00 AM
razi
Mar 29, 2015 10:13 AM
razi
Aug 12, 2013 03:57 PM
Christian1
Mar 23, 2011 10:43 PM
