Sounds like chains dragging?
Old Sep 18, 2017 | 01:51 PM
cait.roberts's Avatar
Default Sounds like chains dragging?
Sorry if there is already a post about this. I'm new to this forum and drive a 2007 Mitsubishi Outlander.
Whenever I drive, it sounds like there are chains dragging. I've double checked underneath and I don't see anything. The problem happens when I'm coasting or accelerating. When I hit the brakes the sound seems to stop but as soon as I hit the gas, the sound reappears. Any idea what might be causing this?
Old Sep 25, 2017 | 12:04 PM
binzd's Avatar
Ok, so in describing your experience a couple things come to mind.
Whether coasting or accelerating removes the drive train from the equation because when you hit the brakes the noise stops, therefore it must be either something in the brakes or close to the brakes. (otherwise the noise would increase/speedup or decrease/slow down with the engine speed)
Sometimes, pieces of debris get caught in the brake area, there could also be a problem with a loose piece of hardware that it pressed upon by the braking system and thus preventing the noise.
Either way, I would get to a brake shop right away for a full inspection
Old Sep 25, 2017 | 01:39 PM
Default Fixed it!
I changed my brakes and rotors over the weekend and the sound is gone. It was definitely something going on with the brakes. Thanks for the reply!
cait.roberts
Oct 27, 2017 04:04 PM
cait.roberts
Sep 18, 2017 01:21 PM
burnmyeyes
Oct 7, 2006 01:42 PM
00Mirage
Aug 4, 2006 02:07 PM
Daithi
May 29, 2005 06:09 PM
