Spark Plug Model for 2007 Outlander
Old Jan 28, 2009 | 02:14 AM
doubler's Avatar
Default Spark Plug Model for 2007 Outlander
Hi there,
I am a happy 2007 Outlander XLS owner. My love one isabout to reach48000km. Dealer in greater Vancouver areais asking $369.99 plus tax for the regular maintanence. I think it way too much.
Can someone tell me the model# of the spark plugs? I know the 2.4 litre Outlander use NGK FR5EI or DENSO K16PSR-B8. Does my 3.0 litre Outlanderuse the samemodel? Where can I get the spark plug?
As for the 48000km maintanence,if I decide togoDIY, any special things I should know?
Thanks in advance.
DoubleR(Vancouver, Canada)
Old Jan 28, 2009 | 02:30 AM
BrodyGuy's Avatar
Default RE: Spark Plug Model for 2007 Outlander
simple as walk into canadian tire and look it up in the book that sits in the spark plug aisle.
Old Jan 28, 2009 | 06:39 AM
Mislovic's Avatar
If i remember correctly, the v6 uses the long life plugs. Only need to change every 100k km.
Old Jan 28, 2009 | 07:41 AM
chenarm's Avatar
MY dealer here in Montreal charges $199.95 for the 48,000km Service
It includes
[ul][*]Oil change[*]Oil filter replacement[*]clean air filter (extra for replacement)[*]check belt[*]lubricate all locks and hinges[*]inspect fuel and anti-pollution system[*]verify coolant components[*]replace spark plugs[*]flush and replace transmission fluid[*]check steering and suspension components[*]service front and rear brakes[*]inspect brake lines and hoses (including ABS)[*]inspect exhaust system[/ul]
Spark plugs are DENSO SXU22HDR8 or NGK ILKR7B8
Old Jan 28, 2009 | 09:55 AM
azjake's Avatar
I have an 08 ES with the 2.4L 4 cyl engine. The warranty manual states that it has the iridium tipped spark plugs that only need to be changed every 100,000 miles. Don't know if this also applies to 07 models, but I would check first before buying any plugs.
Old Jan 28, 2009 | 10:37 AM
BoldlyGoingNowhere's Avatar
Before you decide to DIY make sure you dont have to drop the engine mounts to get to the rear plugs against the firewall. Seems to be a common design when cramming a V6 into a small space.
I am not saying at all that the Outlander is this way, just a beware kinda thing.
Old Jan 28, 2009 | 10:55 AM
Wheeldog's Avatar
ORIGINAL: BoldlyGoingNowhere
Along these lines, why not download the appropriate section from the service manual? This will tell you not only what you might need to move around, but it will also tell you the installation torque for the plugs, confirm the plug part number, etc.. . .
Old Jan 28, 2009 | 02:08 PM
chenarm's Avatar
Don't bother with the plugs the Mitsubishi Canada server usage schedule says to change them at 96,000Km if they are Iridium plugs.
Outlander007
Dec 21, 2014 03:02 PM
Border
Feb 16, 2012 07:16 PM
jhrbanker
Dec 18, 2011 08:10 AM
joeba
Mar 8, 2010 12:05 PM
spyder4g63t
Oct 30, 2006 09:07 PM
