Is there a transfer case oil in 4wd?
Old Jan 17, 2011 | 06:13 PM
klas's Avatar
Default Is there a transfer case oil in 4wd?
Just wanted to start a separate subject on this. Does 4wd version have transfer case oil? Has anyone replace transfer case oil or know how it's done?
Old Jan 17, 2011 | 09:29 PM
ccernst's Avatar
yes there is. check out the service manual for the location. but there is a fill hole and a drain hole. take the fill hole out first (so you know it can come out...you don't want to drain with no way to fill it back up!), then drain the fluid into a pan. the drain plug is magnetized, so clean it off and put it back in. Refilling the transfercase is a bit difficult, but I used an oil can pump that was cleaned out well. I used Mobile1 75w90 in my tcase and rear differential.
my oil can pump looked a lot like this:
Old Jan 18, 2011 | 01:02 AM
klas's Avatar
Thanks! I'll give it a try!
Old Jan 18, 2011 | 04:06 PM
RAMON-'s Avatar
Good info! Thank you.
Old Jan 22, 2011 | 10:25 PM
tcp's Avatar
tcp
Default done
I swapped both out at 30k kms. It appeared to be quite dirty already. I replaced the stock stuff with redline 75w140.
Old Apr 12, 2011 | 07:27 PM
n0c7's Avatar
30k? Wow. The severe service manual doesn't mention changing the transfer oil until 96,000 km and only recommends checking the rear oil level but never changing it. Wondering how necessary it is.
Old Apr 13, 2011 | 09:17 AM
tcp's Avatar
tcp
Default Necessary
I doubt that the oil was completely depleted and needed to be changed at 30k kms, but I figured it would be better to be safe and I felt like tinkering, so I swapped the rear differential and the transfer case fluids to a high quality synthetic. Now I can be sure they are good for a looooong time. Preventative maintenance and my own need to play. I will do a drain/refill of the transmission fluid around 50k kms and probably every 50k after that as well.
Old Apr 13, 2011 | 10:08 AM
n0c7's Avatar
Gotcha. Is there a manual available yet that outlines these procedures for DIY? I usually buy the Haynes manuals but there isn't one available for us yet.
Old Apr 16, 2011 | 02:05 PM
ccernst's Avatar
there is a sticky for the manual...the 07+ north american is linked 2nd or 3rd page from the last...has just about anything you want to do to the car.
ideally, this is really easy...the rear diff is a bit difficult to get to. get an oil can like above and it makes it a ton easier.
Old Apr 20, 2011 | 01:54 PM
newoutlanderfan's Avatar
Would doing that yourself at a different interval than stated in the manual void any warranty? Or do you have to change it again at the started interval in the manual?
