Throttle position sensor?
Old Mar 30, 2010 | 01:29 PM
bOutty's Avatar
Default Throttle position sensor?
Hey guys,
I have an 06 outlander with about 55,000 miles. Recently I've been having an intermittent problem where the car will not rev past 2k rpm. the check engine light comes on also. I got the codes ran and it looks like it indicates a problem with the throttle sensor. Does anyone know where this is located on the car? Easy to swap out myself?
thanks
Old Mar 30, 2010 | 03:35 PM
ccernst's Avatar
your throttle position sensor will be located between your air filter and your intake manifold...attached to the throttle body.
you should really contact your service dept. For the '07 model, the service manual says "Throttle body assembly (incorporating throttle position sensor)" when looking at the sensor layout diagram. I can't imagine you'd have to buy the whole assembly. However, I cannot find just the sensor on the OEM parts websites. Maybe you can remove the sensor and see if there is a part number moulded into the part.
Tennysballs
Apr 25, 2012 12:56 AM
kenshi
Oct 17, 2011 07:50 PM
jrmdir
Jun 19, 2010 02:03 PM
FARDJA
Jun 28, 2005 01:25 PM
art1217
May 11, 2005 09:15 PM
