Timing Belt?
Old Dec 26, 2005 | 11:51 AM
BigMoody1's Avatar
Default Timing Belt?
Hey y'all...finally found a place to chat about my 2003 Outlander. Great vehicle!
Okay, here's the question: We had to take it in this AM for a water pump. We had an extended warranty, so no big deal.
Now we took it to a dealer (was this mistake #1?), and here's what they said. It also needs a timing belt, a drive belt, and a balancer belt.
Excuse me? Since when does any car need a timing belt at 51,000 miles? Does this sound odd?
And the drive belt I can see, okay. But what the heck is a balancer belt?
Can anyone lead me in the right direction on these questions? Is the dealer trying to pull a fast one?
Larry
Old Dec 26, 2005 | 09:31 PM
Joel_CA's Avatar
Default RE: Timing Belt?
You'll need to remove the timing belt in order to replace the water pump- with that being the case, you might as well install a new Tbelt while you're at it. There are 2 Timing belts back there. You should replace BOTH when doing a Tbelt service. If the extended warranty is paying for the water pump, the only additional labor you should be paying for is for the second timing belt (remember, the main timing belt needs to be removed to change the water pump therefore no additional labor should be charged for it. The rest of the charges should be in parts only (Both timing belts, etc). Good Luck!
Joel, CA
Old Dec 29, 2005 | 12:16 PM
BigMoody1's Avatar
Thank you!
I'll give the dealer the benefit of the doubt, but the price we were quoted after we let him know all that was involved in replacing the belts was $200 less. I'll just assume he was giving us a price to consider for later if we didn't have it done now
Thanks again!
Old Jan 5, 2006 | 12:34 PM
JMC's Avatar
JMC
Exactly Joel! WOO!
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
